Stepper online A6 Servo motor as Spindle motor
1 year 2 days ago #337459 by Hakan
Very difficult to say, you give me no clues.
You have to show the error messages from linuxcnc startup, that is the biggest help.
I kind of think you have not installed the component?
"sudo halcompile --install cia402pv.comp"
should put the component in the right place.
Anyway, I have to see the errors you get. A general description is not enough.
1 year 2 days ago #337462 by Will_cnc
cnc@raspberrypi:~$ sudo halcompile --install cia402pv.comp
File "/usr/bin/halcompile", line 1553, in <module>
main()
File "/usr/bin/halcompile", line 1523, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1363, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 434, in parse
f = open(filename).read()
FileNotFoundError: [Errno 2] No such file or directory: 'cia402pv.comp'
1 year 2 days ago #337463 by Will_cnc
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/probe_basic_dev'
Machine configuration file is 'EL8_machine.ini'
INIFILE=/home/cnc/linuxcnc/configs/probe_basic_dev/EL8_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=el8_homecomp
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
linuxcnc TPMOD=tpmod HOMEMOD=el8_homecomp EMCMOT=motmod
Found file(REL): ./hallib/EL8_machine.hal
Debug file information:
Note: Using POSIX realtime
cia402pv: dlopen: /usr/lib/linuxcnc/modules/cia402pv.so: cannot open shared object file: No such file or directory
./hallib/EL8_machine.hal:9: waitpid failed /usr/bin/rtapi_app cia402pv
./hallib/EL8_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./hallib/EL8_machine.hal:9: insmod for cia402pv failed, returned -1
2207
Stopping realtime threads
Unloading hal components
1 year 2 days ago #337475 by Hakan
Be in the directory were you have downloaded cia402pv.comp
and there do "sudo halcompile --install cia402pv.comp"
Easy to spot with the error messages, that helps a lot.
1 year 2 days ago #337480 by Will_cnc
Hi Hakan
Thanks for the help I have configured to the directory now, but have a new error message ?
1 year 2 days ago #337481 by Will_cnc
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.6
VERSION=1.1
TPMOD=
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
HAL: ERROR: function 'cia402pv.Spindle.read-all' not found
./hallib/EL8_machine.hal:18: addf failed
2439
Time to create page: 0.470 seconds
