[SOLVED]v2.9 and not the perpendicularity of X and Y matrixkins + XXYYZ
16 Nov 2025 07:28 - 21 Nov 2025 14:42 #338496 by abs32
Colleagues, I am currently using v2.8.4 with the XXYYZ scheme. Two sensors X1 and X2, when performing Home, help set the portal to the working position. I use a rack as a drive and to reduce the influence of gaps (so that the gear is always in contact with the rack on one side) I adjusted X1 and X2 so that a pre-elastic stress occurs. But to correct this, use the setting (additional module) -
#20241015 переход на программную корреkцию осей
    #loadrt [KINS]KINEMATICS
#вариант программной коррекции осей
#вариант простой, коррекция вдоль У по двум крайним точка
loadrt relkins coordinates=XXYYZ adjust=X from=Y steps=2 step_size=1030 offset=0
    setp relkins.adjX.Y0 0
    setp relkins.adjX.Y1030 -2.6
There is a question about switching to version 2.9. Accordingly, the question is - in version 2.9, how can you indicate (correct) the deviation of the X*Y geometry from the normal one (90 degrees)?
Last edit: 21 Nov 2025 14:42 by abs32.
16 Nov 2025 12:37 #338503 by Aciera
I'm not familiar with 'relkins' but it will likely need updating due to the addition of the switchable kinematic feature. Discussion:
forum.linuxcnc.org/49-basic-configuratio...-xyz?start=10#311322
However there is a hal component included in version 2.9 that should handle all kinds of skew corrections:
www.linuxcnc.org/docs/devel/html/man/man9/matrixkins.9.html
16 Nov 2025 12:48 #338505 by abs32
sounds really good, thanks for the answer.
Are there any configuration examples somewhere? that loadrt is clear.
The current version 2.8.4 I can -
1. enable
2. launch a geometry check program, which, based on the results of the Sonde of the first class square, will calculate and tell me the amount of deviation from the perpendicular
3. Without turning off the program, I can enter a command like - in the terminal -
halcmd setp relkins.adjX.Y1030 -1.82
and get the corrected geometry without restarting the program.
How to do this in version 2.9? are there any examples?
16 Nov 2025 13:11 - 16 Nov 2025 13:15 #338508 by abs32
From the description at the link I see the following alorhythm -
1. I know the amount of deviation
2. in the case of XU, I need to explicitly specify the parameter for the formula -
X_joint = C_xx * X_axis + C_xy * Y_axis + C_xz * Z_axis
Those. I know the coefficient from clause 1
C_xx = 1
C_xy = (deviation X divided by width Y)
But what are the rules of use, syntax, examples?
loadrt matrixkins count=0
C_xx = 1
C_xy = 0.03
or
C_xy = [3/100]
or otherwise?
how to change the C_xy parameter on the fly without rebooting the program?
if loading a component requires specifying the contact number count=N, then N is what, what are the options? And where should this count be specified in the C_xy job?
In general, we need examples of syntax and application
In man, the example section of the configuration file shines with emptiness
Last edit: 16 Nov 2025 13:15 by abs32.
16 Nov 2025 13:42 #338510 by Aciera
If you attach the code of your current 'relkins' component I can have a look at updating it to be used in version 2.9
16 Nov 2025 14:22 - 16 Nov 2025 14:26 #338511 by abs32
Thank you, however, this is not necessary. If you already have a Matrixkins component built into the LinuxCNC kernel, then you need to use it. According to the description, it is quite suitable. The main thing is to understand the configuration synatxis for hal.
According to the description, the component built into the kernel solves issues of three axes at once. Simple (linear), but closes.
I don’t have the realkins component itself. The forum where this component was published has already died. The module is here. That's exactly what's holding me up on version 2.8.4
Last edit: 16 Nov 2025 14:26 by abs32.
16 Nov 2025 15:37 #338520 by Aciera
That 'relkins.c' is a bit more effort than I'm willing to put into it.
Maybe have a look at the rather extensive comments in the source code for matrixkins, there are examples no how to set the parameters:
github.com/LinuxCNC/linuxcnc/blob/master...ents/matrixkins.comp
16 Nov 2025 16:42 #338526 by abs32
Thank you, the comments in the source code are much less detailed than in man (this is strange). It would be right to bring the man to the proper level. Thanks again. When I install 2.9.x I will publish detailed startup instructions.
20 Nov 2025 14:37 - 20 Nov 2025 15:04 #338800 by abs32
Colleagues,
I installed the kernel 5.4.290 + the linuxcnc 2.9.4 build that came with it
With the kinematics option KINEMATICS = trivkins coordinates=XXYYZ, everything starts and works.
We have a description here -
the example section of hal + ini files is empty.
We also have a description here -
where examples of specifying matrix elements are indicated.
However, there are no examples for hal + ini.
I tried to do the following by analogy with other methods -
HAL -
#2025-11-20 для версии 2.9.4
#программная коррекция
#https://linuxcnc.org/docs/devel/html/man/man9/matrixkins.9.html
#https://github.com/LinuxCNC/linuxcnc/blob/master/src/hal/components/matrixkins.comp
loadrt matrixkins
setp matrixkins.C_xy 0 # Skew Y axis towards X axis
setp matrixkins.C_xx 1 # X axis scale
setp matrixkins.C_xz 0 # Skew Z axis towards X axis
setp matrixkins.C_yx 0 # Skew X axis towards Y axis
setp matrixkins.C_yy 1 # Y axis scale
setp matrixkins.C_yz 0 # Skew Z axis towards Y axis
setp matrixkins.C_zx 0 # Skew X axis towards Z axis
setp matrixkins.C_zy 0 # Skew Y axis towards Z axis
setp matrixkins.C_zz 1 # Z axis scale
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0,0,0
INI -
[KINS]
JOINTS = 5
#2025-11-20 для 2.9.4
#KINEMATICS = trivkins coordinates=XXYYZ
KINEMATICS=matrixkins coordinates=XXYYZ
When you try to launch it, it drops and shows an error -
Debug file information:
./t.hal:16: Can't find module 'matrixkins' in /usr/realtime-5.4.290-rtai-amd64/modules/linuxcnc
1485
Stopping realtime threads
Unloading hal components
for kernel 5.4.254, the situation and error are exactly the same (with corresponding linuxcnc + linuxcnc-dev)
how to fix this?
I note an error in man - there is no [KINS] section in the HAL file, there is such a section in ini, st 149 -
Last edit: 20 Nov 2025 15:04 by abs32.
20 Nov 2025 16:11 #338802 by Aciera
1. Remove 'loadrt matrixkins' from your hal file
2. The KINEMATICS entry of the [KINS] section in your ini file needs to look like this (matrixkins does not support the 'coordinates' parameter):
Time to create page: 0.135 seconds
