Mesa 5i25+7i77 plug-n-go configuration
- mik1965
15 May 2013 18:00 #34124
by mik1965
Replied by mik1965 on topic Mesa 5i25+7i77 plug-n-go configuration
Good day!
We accomplishments of your recommendations, changed the firmware card 5i25. Unfortunately, there have been no changes. I think there is some problem in the hardware section.
Thanks for the help!
- pws
15 May 2013 20:13 #34130
by pws
Replied by pws on topic Mesa 5i25+7i77 plug-n-go configuration
make sure you do a full power cycle of the computer containing the 5i25 after you update the firmware.
The following user(s) said Thank You: mik1965
- ebrummer
16 May 2013 07:40 - 16 May 2013 07:53 #34167
by ebrummer
Replied by ebrummer on topic Mesa 5i25+7i77 plug-n-go configuration
I used the script posted to copy the Mesa config files over properly and then ran PNCconf. I set everything up as best I could and then the very last menu in PNCconf where you hit apply gives me this error:
PNCconf encountered an error. The following information may be useful in troubleshooting:
Traceback (most recent call list):
File "usr/bin/pncconf", line 8428, in on_complete_finish
self.data.save()
File "/usr/bin/pncconf", line 3514, in save
self.write_halfile(base)
File "/usr/bin/pncconf", line 2554, in write_halfile
if "m1" in self["mesa0sserial0_%dsubboard"% (i-1)]:
File "/usr/bin/pncconf", line 3672, in __getitem__
return getattr(self, item)
AttributeError: Data instance has no attribute 'mesa0sserioal0_5subboard'
EDIT: I redid the setup and it worked this time...
self.data.save()
Last edit: 16 May 2013 07:53 by ebrummer. Reason: Solved sorta
- mik1965
16 May 2013 15:04 #34173
by mik1965
Yes!!! Works! Of course, it was necessary to restart the system. Thank you so much, PCW! It has started to work here with this firmware
7i77x2.bit
halcmd show
halcmd show
- 33zy
14 Mar 2014 08:49 #44792
by 33zy
Replied by 33zy on topic Mesa 5i25+7i77 plug-n-go configuration
It has been a few months since the last post regarding the 5i25 7i77.
I recently received the "plug and go" kit.
I have downloaded the hal and ini, files from mesa and linux cnc opens.
I adjusted the pin for 5v, and have supplied 20v field i/o.
I printed/read the linux manuals from documentation
My intent is to set the system up for a 3 axis cnc.
My question is if I am on the "correct" or simplest path, I notice some discussion of PNCconfig and other "paths" and I am curious if options to just select the 5125 or 7i77 have not been added since may of 2013.
5i25 7i77
driver = be25a20
encoder = differential
servo = powertron
Open questions?
coolant
estop
home
Any assist is appreciated, i am still trying to understand the hal architecture, the wiring diagram posted earlier in the thread was helpful.
Thank you in advance,
5i25 7i77
driver = be25a20
servo = powertron
Open questions?
coolant
estop
home
- cncbasher
- Thank you received: 288
14 Mar 2014 16:54 #44804
by cncbasher
Replied by cncbasher on topic Mesa 5i25+7i77 plug-n-go configuration
if your running the latest version , then pncconfig should get you close , i do know that Chris is integrating 5i25 into pncconf at the moment
if their are any specific wiring problems your experiencing then , lets sort them one at a time , and in the process while looking at a specific problem
you will learn very quickly on configuration , rather than trying to merge a thousand problems into one haha ..
it's usually the case to use pncconf to get you started and from then on edit the files by hand , it's not that difficult , once you get started
even using pncconf to add say home to a dummy configuration , then copy the snippet required into your real config
- Thank you received: 4992
14 Mar 2014 17:19 #44805
If you have a "near enough" config then you might as well stick with it and hand modify.
Coolant is very easy.or similar.
It will help a lot to have a list of all the pins. Once you have the list. you can look for useful ones.
Open a terminal and typeYou can then copy and paste into a text editor. If you prefer you can pipe the output straight to a file
Replied by andypugh on topic Mesa 5i25+7i77 plug-n-go configuration
Open questions?
coolant
estop
home
net coolant-flood iocontrol.0.coolant-flood hm2_5i25.0.7i77.0.digout00
halcmd show pin
halcmd show param
halcmd show pin > pins.txt
halcmd show param > params.txt
- 33zy
15 Mar 2014 15:06 #44835
by 33zy
$ haldmd show param
RTAPI: ERROR: could not open shared memory (errno=2)
segmentation fault
the show pin work, but i am a bit unlcear on how to decipher the pin data
segmentation fault
- 33zy
15 Mar 2014 15:24 - 15 Mar 2014 15:28 #44836
by 33zy
attached subject show pin file
Last edit: 15 Mar 2014 15:28 by 33zy. Reason: no file
15 Mar 2014 19:23 #44845
That's odd. I assume you typed "halcmd" really?
Was LinuxCNC up and running at the time?
$ haldmd show param
segmentation fault
