Mesa 5i25+7i77 plug-n-go configuration
13 Jan 2015 10:49 - 13 Jan 2015 10:55 #54958 by PCW
Replied by PCW on topic Mesa 5i25+7i77 plug-n-go configuration
There is no base thread needed
If it runs away you probably have the output polarity wrong
this is fixed by changing the sign of the analog output scalemax parameter
Also you should have gotten a fault that stops the drives before 5 inches of motion
unless you have the ferror limits set to many inches
(I would not set ferror limits wider than about an inch maximum)
also I would probably set FF1 to 0 and P fairly low to start (say 5)
Last edit: 13 Jan 2015 10:55 by PCW.
Time to create page: 0.080 seconds
