Mesa 5i25+7i77 plug-n-go configuration
- Thank you received: 5261
23 Dec 2014 02:00 #54231
Replied by PCW on topic Mesa 5i25+7i77 plug-n-go configuration
Yes the drives signal gnd can be returned to TB5 pin 3 (analog gnd) with a separate wire
also, there should be no explicit connection of any field I/O pin to the analog signals so
the field power gnd connection should be removed
- 33zy
28 Dec 2014 06:50 #54328
by 33zy
Replied by 33zy on topic Mesa 5i25+7i77 plug-n-go configuration
I checked the voltage at TB5 from pin 3 to pin 4. (with all TB5 wires disconnected)
I get 1.1volt with Linux off.
I have the 5v supplied at Tb1 from the 5i25, that is currently showing 4.8.
My interpretation of your statement is that the 1.1volt reading indicates a bad board? because we would expect to get zero at this location.
I checked the 3&4 pins of other axis and I get a similar reading approx. 1.1volts
Is it time to order a new board?
fixing the signal ground to pin 3 instead of field ground had no effect
29 Dec 2014 03:56 #54345
I would request a RMA number from Mesa for the 7I77 and when you get the number,
send the 7I77 back to Mesa for evaluation, repair and possible replacement
08 Jan 2015 05:27 #54730
33zy: we have received and repaired and returned your 7I77
Since I dont have any contact information I will post this here
The problem found was a bad 74ACT04, This likely indicates
that the7I77s 5V supply was wrong (Either backwards or >7V)
So please check your power supplies before re-installing the 7I77
- 33zy
11 Jan 2015 06:38 #54870
by 33zy
Thank you very much for your assistance. We received the boards. After checking field power 24v and using the 5i25 5v, we have reinstalled.
When I hit the soft enable, the drive enables and waits for a command. This is good progress.
When I manually jog the machine, I now get a following error as it appears to run away. I increased the ferror to 1.0 in an effort to better understand.
I am assuming I need to tune the drives?
Is their a recommended process for tuning the drives?
Thankyou
Thankyou
- FloppyDisk
- Thank you received: 3
11 Jan 2015 06:48 #54871
by FloppyDisk
Replied by FloppyDisk on topic Mesa 5i25+7i77 plug-n-go configuration
John Thornton has a webpage tutorial he put together on servo tuning, this might help:
gnipsel.com/linuxcnc/tuning/index.html
I picked it off one of these forum topics.
11 Jan 2015 09:15 - 11 Jan 2015 09:16 #54872
If the encoder readings are in the correct direction and scaled properly,
and you get a servo runaway, you will have to reverse the output polarity in the hal file
Last edit: 11 Jan 2015 09:16 by PCW.
- 33zy
12 Jan 2015 04:09 #54903
by 33zy
"Set encoder scale Use the machine data to calculate the number of encoder counts per inch (or mm). For example, if your machine has 5 turn per inch ballscrews, a 40 tooth timing belt pulley on the leadscrew, a 20 tooth pulley on the motor, and a 512 cycle per revolution (2048 count per revolution) encoder, the scale is 5 turns per inch * ( 40 teeth on screw / 20 teeth on motor ) * 2048 counts/rev = 20480 counts per inch. The position-scale parameter of the encoder HAL block should therefore be 20480. Once you set the scale parameter, then the 'position' HAL pin shows the axis position in inches (or mm). "
from the ini file
INPUT_SCALE = 20480
OUTPUT_SCALE = -1.000
corresponding to the HAL line
# encoder feedback
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.scale [AXIS_0]INPUT_SCALE
# position command signals
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE
Am I misinterpreting the tutorial line above?
When the tutorial refers to the "position HAL pin" how can I figure out which on that is?
Thank you
from the ini file
INPUT_SCALE = 20480
# encoder feedback
Thank you
12 Jan 2015 05:24 #54904
if you move the axis (with the drives disabled)
is the encoder scaling and direction correct?
(as read on the axis DRO and verified against a dial indicator, caliper or some other position reference)
- 33zy
13 Jan 2015 09:40 - 13 Jan 2015 09:50 #54957
by 33zy
table direction and deflection verified against Linux display and correct. Sorry for that distraction.
When I soft enable Linux, all is well.
Then I hit jog (.1).
The machine jogs in the correct direction followed by brief pause and it then runs away 5 to 8 inches to the right with a following error.
Back to tuning. I have been reading about setting base period and servo period. I only see servo period in the ini, is that OK? Am I missing base period?
I started with this (ini & hal) files as a baseline because the config didn't have a config for 7i77/5i25/servo, so I am cautious that I could have started from a poor entry point.
[EMCMOT]
EMCMOT = motmod
# Timeout for comm to emcmot, in seconds
COMM_TIMEOUT = 1.0
# Interval between tries to emcmot, in seconds
COMM_WAIT = 0.010
# Servo task period, in nanoseconds
SERVO_PERIOD = 1000000
# PID tuning params
DEADBAND = 0.000015
P = 100.0
I = 0.000
D = 0.000
FF0 = 0.000
FF1 = 1.000
FF2 = 0.0
BIAS = 0.000
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
# PID tuning params
DEADBAND = 0.000015
P = 100.0
I = 0.000
D = 0.000
FF0 = 0.000
FF1 = 1.000
FF2 = 0.0
BIAS = 0.000
Last edit: 13 Jan 2015 09:50 by 33zy.
Time to create page: 0.087 seconds
