No Luck with 5i25 & 7i76
19 Mar 2014 15:06 #44972 by bottleworks
No Luck with 5i25 & 7i76 was created by bottleworks
I'm just no having any luck with my Mesa setup on a new mill I'm working on. I've tried to have VIN powered from an external power supply. After realizing, you really can't do it, I'm having it powered by the 5i25. I have both the VIN and Field power LEDs on. The current issue is LinuxCNC rejects my config and I don't see why. This was produced with pncconf. It's taking issue with my GPIO outputs. Disabling #9 just makes it complain about #10, etc.
I should say, I don't know if my stepper setup is remotely correct. There is a huge disconnect between the referencing of the 7i76 in pncconf and the terminals on the 7i76. So, I was just going to try guessing and checking.
Any help would be great. I've attached data. Thanks!
19 Mar 2014 21:25 #44981 by PCW
Replied by PCW on topic No Luck with 5i25 & 7i76
Typically not finding field I/O indicates a problem with power supplies or FPGA card/7I76 cabling
can you list:
1. 5I25 jumper settings
2. 7I76 jumper settings
3. External power supply connections and voltages
The following user(s) said Thank You: bottleworks
20 Mar 2014 01:55 #44985 by bottleworks
Replied by bottleworks on topic No Luck with 5i25 & 7i76
Hello.
Right now I have both the VIN and field LEDs on. I'm running VIN off of the 5i25. On the 7i76, W2 is in left hand position. W1 is in right hand position. On the 5i25, W1 and W2 are in the up position. The field voltage is 5V. Checking VIN with a meter, I'm only getting 0.3V between pin 5 and 8 on TB1. So, that doesn't sound right. I would rather have VIN powered externally, however when I configured the jumpers for that (not current config) and applied 5v to pin 5, I got no VIN LED. I also tried 12v to pin 5 with the same result.
20 Mar 2014 01:59 #44986 by bottleworks
I've attached. All stated is with everything disconnected but TB1 and TB2. I'm trying to eliminate anything external to the MESA setup.
20 Mar 2014 04:09 #44990 by PCW
Sounds like you dont have VIN powered
For this you need:
12V GND - TB1 pin 8
5V GND TB1 pin 8
+5V TB1 pin 1
+12V TB1 pin 5
W1 RIGHT!
20 Mar 2014 05:30 #44993 by bottleworks
I have applied +12v to TB1-Pin 5. CR1 LED will no light. W1 & W2 both in right hand position on the 7i76. I moved both W1 & W2 to the down position on the 5i25. LinuxCNC errors out and no VIN power LED. I believe my MESA cards are DOA.
20 Mar 2014 05:37 #44994 by bottleworks
I have no LEDs on the 5i25. Shouldn't I have something?
20 Mar 2014 05:39 - 20 Mar 2014 05:51 #44995 by PCW
You still have power wired incorrectly
7I76:
12V GND - TB1 pin 8
5V GND TB1 pin 8
+5V TB1 pin 1
(5V VFIELD)
+12V TB1 pin 5
(12V VIN)
VIN is 12V, VFIELD is 5V
Note CR2 in VFIELD LED
W1 RIGHT
separate VIN and VFIELD
W2 LEFT
Get 5V logic power from 5I25
Note CR1 indicates 5V logic power
5I25:
W2 UP
Supply cable power for 7I76 logic
Note: normally there are no LEDs illuminated on the 5I25
Last edit: 20 Mar 2014 05:51 by PCW.
20 Mar 2014 05:52 - 20 Mar 2014 05:54 #44996 by bottleworks
7I76:
12V GND - TB1 pin 8
5V GND TB1 pin 8
Done
+5V TB1 pin 1
(5V VFIELD)
Done
+12V TB1 pin 5
(12V VIN)
Done
CR2 is on. CR1 is not.
W1 RIGHT
Done
W2 LEFT
Hold on. Your manual specifically states that I will cause damage if I do that.
5I25
W2 UP
TB1 pin 1 through 4 all have 5V relative to pin 8. Pin 5 has 12v relative to pin 8.
Last edit: 20 Mar 2014 05:54 by bottleworks.
20 Mar 2014 06:15 #44997 by PCW
You are not supposed to apply 5V logic power to to 7I76 (VIA TB3) when the 5I25 jumper is up
VIN and VFIELD are completely independent and isolated from logic power so this
warning does not apply to them
Time to create page: 0.080 seconds
