Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
8 years 1 month ago #117109 by tecno
Fixed
./GB_2speed.hal:170: Pin 'GB-2speed.0.message.1' does not exist
So we have errors probably on all lines below
net m1 GB-2speed.0.message.1 => gear1.trigger net m2 GB-2speed.0.message.2 => gear2.trigger net m3 GB-2speed.0.message.3 => gear3.trigger net m4 GB-2speed.0.message.4 => gear4.trigger net m5 GB-2speed.0.message.5 => gear5.trigger net m6 GB-2speed.0.message.6 => gear6.trigger net m7 GB-2speed.0.message.7 => gear7.trigger net m8 GB-2speed.0.message.8 => gear8.trigger net m9 GB-2speed.0.message.9 => gear9.trigger net m10 GB-2speed.0.message.10 => gear10.trigger net m11 GB-2speed.0.message.11 => gear11.trigger net m12 GB-2speed.0.message.12 => gear12.trigger net m13 GB-2speed.0.message.13 => gear13.trigger
8 years 1 month ago - 8 years 1 month ago #117111 by andypugh
halrun
loadrt GB_2speed
show pin
exit
It's probably message.01
Last edit: 8 years 1 month ago by andypugh.
8 years 1 month ago - 8 years 1 month ago #117112 by tecno
bengt@CombiMll ~ $ halrun halcmd: loadrt GB_2speed Note: Using POSIX realtime halcmd: show pin Component Pins: Owner Type Dir Value Name 6 bit IN FALSE GB-2speed.0.gear-A 6 bit IN FALSE GB-2speed.0.gear-B 6 bit IN FALSE GB-2speed.0.gear-C 6 bit IN FALSE GB-2speed.0.gear-D 6 bit IN FALSE GB-2speed.0.gear-E 6 bit IN FALSE GB-2speed.0.gear-high 6 u32 OUT 0x00000000 GB-2speed.0.gear-required 6 bit OUT FALSE GB-2speed.0.message-00 6 bit OUT FALSE GB-2speed.0.message-01 6 bit OUT FALSE GB-2speed.0.message-02 6 bit OUT FALSE GB-2speed.0.message-03 6 bit OUT FALSE GB-2speed.0.message-04 6 bit OUT FALSE GB-2speed.0.message-05 6 bit OUT FALSE GB-2speed.0.message-06 6 bit OUT FALSE GB-2speed.0.message-07 6 bit OUT FALSE GB-2speed.0.message-08 6 bit OUT FALSE GB-2speed.0.message-09 6 bit OUT FALSE GB-2speed.0.message-10 6 bit OUT FALSE GB-2speed.0.message-11 6 bit OUT FALSE GB-2speed.0.message-12 6 bit OUT FALSE GB-2speed.0.message-13 6 bit IN FALSE GB-2speed.0.motor-high 6 float OUT 0 GB-2speed.0.motor-speed-out 6 bit IN FALSE GB-2speed.0.spindle-enable-in 6 bit OUT FALSE GB-2speed.0.spindle-enable-out 6 float IN 0 GB-2speed.0.spindle-speed-in 6 s32 OUT 0 GB-2speed.0.time halcmd: exit Note: Using POSIX realtime
Message 00 ?
Last edit: 8 years 1 month ago by tecno. Reason: added text
8 years 1 month ago - 8 years 1 month ago #117114 by tecno
./GB_2speed.hal:170: Pin 'GB-2speed.0.message.01' does not exist
Do we need to setp something?
8 years 1 month ago #117116 by Todd Zuercher
it is "GB-2speed.0.message-01" not "GB-2speed.0.message.01"
See the difference? (look at the character before the 01)
8 years 1 month ago #117117 by tecno
Thanks Todd!
Will change now test soon.
Time to create page: 0.167 seconds
