Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
8 years 1 month ago #117129 by tecno
Hmmm just pondering
net spindle-vel-cmd-rpm-abs
is above lines command to be changed to
8 years 1 month ago #117143 by tecno
At commanded S80 the frequency out from VFD should be about 32Hz and not as in picture 1.84Hz
50Hz / 125 (max speed in that gear) * 80 = 32Hz
So something is missing, scaling or ratio perhaps in comp or hal?
8 years 1 month ago #117144 by tecno
Assuming ratio's to be separated motor at HighSpeed
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
8 years 1 month ago #117178 by tecno
Is this possible?
setp gear1 => GB-2speed.0.motor-speed-out * 8.00 setp gear2 => GB-2speed.0.motor-speed-out * 6.25 setp gear3 => GB-2speed.0.motor-speed-out * 4.65 setp gear4 => GB-2speed.0.motor-speed-out * 3.70 setp gear5 => GB-2speed.0.motor-speed-out * 2.77 setp gear6 => GB-2speed.0.motor-speed-out * 2.22 setp gear7 => GB-2speed.0.motor-speed-out * 1.68 setp gear8 => GB-2speed.0.motor-speed-out * 1.33 setp gear9 => GB-2speed.0.motor-speed-out * 1.00 setp gear10 => GB-2speed.0.motor-speed-out * 2.10 setp gear11 => GB-2speed.0.motor-speed-out * 1.66 setp gear12 => GB-2speed.0.motor-speed-out * 1.25 setp gear13 => GB-2speed.0.motor-speed-out * 1.00
8 years 1 month ago #117182 by Hakan
Don't think so.
You should most likely look inside the component how the motor-speed-out is calculated.
Maybe you did that already to end up with the factors here, but you can use the halshow to
show the values of the output pins.
And if there is something wrong in the output pins values, and the right logic with the gears work,
you need to look in the code how the wrong value is calculated. It should be possible to follow,
there aren't too many lines of code.
Can you show a screenshot of halshow with all the input pins and output pins of the component
shown when there is an output that troubles you?
8 years 1 month ago #117183 by tecno
S80 commanded
output of 2500 from comp is way off, should be about 640 if my calculation is correct and still it is not acting so as i only get 1.84Hz.
Time to create page: 0.380 seconds
