- Thank you received: 454
Hakan wrote: You can change this line
toCode:motor_speed_out = speeds[13] * (spindle_speed_in / speeds[i]);Code:motor_speed_out = speeds[13] * (spindle_speed_in / speeds[i+1]);
That should give motor-out-speed of 1600 because it is based on max-rpm 2500.
As far as I can see, there is no support in the comp for using different max rpm.
You *can* do like this. But it is never good to interfere in someone's line of thought so if
Andy has a better idea then go for that.
1. Add a variable "double motor_max_speed;" where the other variables are declared.
2. Just above the motor_speed_out lineThis should give about 928 rpm on motor. Assuming 125 spindle rpm at 1450 motor rpm.Code:if (motor_high) motor_max_speed = 2500; else motor_max_speed = 1450; motor_speed_out = motor_max_speed * (spindle_speed_in / speeds[i+1]);
Halcompile and all that to test again.
For the vfd speed, does it need rpm or rps (minutes vs seconds)?
