Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
8 years 1 month ago #117257 by tecno
Hakan wrote: Yes you are right, the table looks ok, although I just checked the two first gears
The message you get, can that be that the message is "off by one" gear?
If so you can change the numbering either in hal or in the comp, but maybe try in the hal file?
Can you see anything why High-Gear is not working = nothing to VFD.
Maybe the comp is needed to be changed and not hal.
8 years 1 month ago #117284 by tecno
tecno wrote: Always better with another pair of eyes, suspected 1step off.
Will dive into this tomorrow, thanks for the help HÃ¥kan always appreciated.
Assuming you are following the election as everybody else in Sweden.
OK, I think I have found the error
actual = (gear_high * 0x40 + motor_high * 0x20
these two are flipped and should be motor_high * 0x40 + gear_high * 0x20
Look in table here forum.linuxcnc.org/39-pncconf/33069-help...ing?start=590#116905
8 years 1 month ago #117289 by tecno
Edited comp file
int speeds[15] = {0, 125, 160,
Deleted 80 so now first gear goes from 0 to 125 (I can live with that ;) )
All gears work up to 1000rpm (not running at correct speeds that I have to tune) with gear settings.
But all gears over 1000rpm involve motor to be set at high speed does not work.
8 years 1 month ago #117294 by tecno
It looks like this with not correct spindle rpm. S160 shows up in gmoccapy as 158 and in reality 74.2rpm
File Name: GB_2speed_...-10.comp
File Size:1.44 KB
8 years 1 month ago #117296 by tecno
tecno wrote: Edited comp file
This must be the problem == No output for motor-high
component GB_2speed;
pin in bit spindle-enable-in;
pin out bit spindle-enable-out;
pin in float spindle-speed-in;
pin out float motor-speed-out;
pin in bit gear-high;
pin in bit motor-high; <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< !!!
pin in bit gear-A;
pin in bit gear-B;
pin in bit gear-C;
pin in bit gear-D;
pin in bit gear-E;
pin out unsigned gear-required;
pin out bit message-##[14];
license "gpl";
How can this be solved? Not interested to have a manual switch for this if possible to have it in comp/hal.
8 years 1 month ago #117305 by tecno
How do I tie motor-high to get output ?
pin out bit motor-high;
pin in bit gear-A;
pin in bit gear-B;
pin in bit gear-C;
pin in bit gear-D;
pin in bit gear-E;
license "gpl";
function _;
FUNCTION(_){
int actual, message, motor_max_speed;
int i;
// These need to be edited to suit the gearbox
int speeds[15] = {0, 125, 160, 215, 270, 360, 450, 595, 750, 1000, 1191, 1500, 2500, 0x1P30};
int reqd_gear[15] = {0x0, 0x01, 0x21, 0x02, 0x22, 0x04, 0x24, 0x08, 0x28, 0x10, 0x48, 0x68, 0x50, 0x70, 0x0};
if (spindle_speed_in == 0) return;
actual = (motor_high * 0x40 + gear_high * 0x20 + gear_A * 0x10 + gear_B * 0x08 + gear_C * 0x04 + gear_D * 0x02 + gear_E * 0x01);
for (i = 0; spindle_speed_in > speeds && i < 14; i++);
gear_required = reqd_gear;
if (gear_required == actual && gear_required != 0x0){ // We are in the right gear
spindle_enable_out = spindle_enable_in;
if (motor_high)
motor_max_speed = 2500;
else
motor_max_speed = 1850;
motor_speed_out = motor_max_speed * (spindle_speed_in / speeds[i+1]);
message = 0;
} else {
int j;
motor_speed_out = 0;
spindle_enable_out = 0;
for (j = 0; j < 13; j++) { message(j) = 0; }
message(i) = 1;
Time to create page: 0.143 seconds
