I went through this learning curve. There are a couple of foundational concepts to wrap your head around first.
Your machine will be a 3 axis machine, composed of FOUR individual "Joints". A joint, in this case is one motor, driving one screw/belt. You will need sections in both your HAL and INI files to configure a 2nd Joint for whichever axis will have two motors on it. In my case it's the Y axis, so my configuration files reference the two joints of the Y axis as :
HAL Config
# JOINT Y1
Settings, blah, blah
and
# JOINT Y2
Settings blah, blah
This allows all the signals and pin assignments for each joint to be made identical, so they both behave the same and both receive instructions when Y axis moves are commanded.
In the INI file, you need to start by correctly defining your geometry. Currently yours says:
GEOMETRY = xyz
Mine says:
GEOMETRY = XYYZ
You'll also need these:
KINS]
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
JOINTS = 4
[TRAJ]
COORDINATES = X Y Y Z
Then below, each joint has it's own configuration label, which I added an additional comment to, in order to clarify the usages:
# 2 Joints in Y Axis
# Joint 1 Y1
[JOINT_1]
Config settings for Y1 here.....
Then new section
# Joint 2 Y2
[JOINT_2]
Config settings for Y2 here...
Immediately after those two sections, a final section ties the tow JOINTS together into the single virtual Y AXIS -- this:
# Axis Y
[AXIS_Y]
MAX_VELOCITY = 50
MAX_ACCELERATION = 80
MIN_LIMIT = 20
MAX_LIMIT = 390
At the risk of embarrassment, I'll share my own files below. You can analyze them and see if it helps define the things that are missing from your setup.
