2 steppers on one axis 5i25 - 7i76
8 years 8 months ago #106348 by chadrat6458
Is this what I need?
2k 1/2w resistor
I hook this up between the power side and the output side of my switch?
8 years 8 months ago #106351 by DanMN
I used these: www.arrow.com/en/products/rs01a2k000jb12/vishay
Rodw used a circuit board for his, but I just soldered mine in as a T-splice to the sensor wire before it gets to the input pin. Page 7 of Norbert's holy gospel of 7i76e configuration has a schematic: forum.linuxcnc.org/27-driver-boards/3191...t?limitstart=0#83622
8 years 8 months ago #106354 by rodw
I checked my notes.I used 2.2 k ohms, 1 W on a 24 volt system.
I always intended to use a board as I had so many switches on the gantry it was convenient to use a DB9 cable and distribute to terminal blocks so I had the room to add the resistors which made it real easy to implement.
8 years 8 months ago - 8 years 8 months ago #106355 by rodw
Finally found a photo
I added a LED to show I had power to the gantry for troubleshooting
Each of the 7 sensors connects to its own 3 input terminal block.
One switch was an ordinary microswitch so no resistor on that one.
Last edit: 8 years 8 months ago by rodw.
8 years 8 months ago #106357 by chadrat6458
I can not home my Y.
Is there anything you can see that is wrong?
8 years 8 months ago #106360 by rodw
I think you are missing the homing sequence settings inyour ini file for each joint
Here is mine with homing switches so just check the docs I linked to earlier for your immediate homing.
HOME_OFFSET = 43 HOME_SEARCH_VEL = -100 HOME_LATCH_VEL = 10 HOME_FINAL_VEL = 50 HOME_USE_INDEX = NO HOME_SEQUENCE = -1
Time to create page: 0.165 seconds
