2 steppers on one axis 5i25 - 7i76
8 years 8 months ago #106297 by chadrat6458
any idea what I am doing wrong?
8 years 8 months ago #106298 by rodw
Todd Zuercher wrote:
rodw wrote: Other idiots build from source.....
I don't know if I'd call them idiots, masochists maybe but not idiots.
Ahh one of the real gurus reports in.... :)
I only compiled from source because after compiling the linux kernel to get my mesa ethernet hardware working, it was so trivial by comparison. It's been a great learning experience.
Do you have any ideas on making both joints respond to the Y button in unhomed mode, or is that not possible?
I don't remember ever seeing them try to move other than in unison. I mostly use Gmoccappy but I do have some axis configs. I just hit home all as I power up becasue usually an unhomed axis won't jog to where I want it to ss it thinks its in a different place. I just had a play then and Both joints move in unison when jogging Y when unhomed from the Axis GUI and my Mesa MPG.
8 years 8 months ago #106299 by rodw
rodw wrote: I just had a play then and Both joints move in unison when jogging Y when unhomed from the Axis GUI and my Mesa MPG.
Its possible that a new version of master has fixed this behaviour as I found a few bugs in homing on Gmoccappy that Norbert fixed and there was a bit of a flurry on some of the other GUIs after the problems I raised were noted.
The following user(s) said Thank You: DanMN
8 years 8 months ago #106301 by rodw
chadrat6458 wrote: any idea what I am doing wrong?
Try from the Synaptics GUI. Check the deb settings there first. So long ago since I did it. (I just type make)
8 years 8 months ago #106302 by cmorley
chadrat6458 wrote: I still can't get one of the steppers to move. I have attached the hal and ini file.
I definately see an error.
look for this line in the Y axis:
net y-pos-cmd => hm2_5i25.0.stepgen.01.position-cmd
change it to:
net y-output <= hm2_5i25.0.stepgen.01.velocity-cmd
i bet you see movement then (hopefully good movement)
Chris M
8 years 8 months ago #106303 by chadrat6458
Now, I am confused. Do I make the change mentioned above or do the joints?
Time to create page: 0.206 seconds
