2 steppers on one axis 5i25 - 7i76
8 years 8 months ago #106318 by DanMN
I wholeheartedly agree with your suggestions on the naming conventions. The cleaner you make it, the easier it is to slog through the 3000 edits you'll make before it's "perfect". I'm still about 1,864 edit away...
8 years 8 months ago #106319 by rodw
Note my comments were directed at CNCzombie's config not yours.
The homing is different in master so make sure you drill down to the right documents
linuxcnc.org/docs/devel/html/config/ini-homing.html
Immediate homing is covered.
Set the homing sequence for Joints 1 and 3 to -1 and you are done!
When you do get your home switches in place, all you need to do to square the gantry is change the HOME_OFFSET
Also I found if you have a shared home/limit switch you need to move the axis off the limit switch with an offset otherwise you will get a limit error as soon as homing is complete (becasue the switch is enabled)
8 years 8 months ago #106320 by cmorley
rodw wrote:
chadrat6458 wrote:
Chis, if its OK, I'll send you an email via the forum and sort out the config sample from there. I think it would be good to sort out pncconf a bit better.
Sound good Rodw
8 years 8 months ago #106326 by rodw
cmorley wrote:
rodw wrote:
Sound good Rodw
Message sent :)
8 years 8 months ago #106341 by chadrat6458
I have some Proximity Switch NPN to use for home/limit switch. Do you guys have any tips on how to wire them up?
8 years 8 months ago - 8 years 8 months ago #106342 by DanMN
On Mesa boards, PNP are the preferred type -- but both me and Rodw have rigged ours with NPN. And by me and Rodw I mean, he did it and I copied him ;)
It requires a pullup resistor. PCW's guidance on the thread below clarified it for me:
forum.linuxcnc.org/27-driver-boards/3191...sheet?start=10#91557
Last edit: 8 years 8 months ago by DanMN.
Time to create page: 0.271 seconds
