pncconfig error
5 years 11 months ago - 5 years 11 months ago #188468 by PCW
Replied by PCW on topic pncconfig error
Did you flash the FPGA card with the 5i25_g540x2.bit firmware?
sudo mesaflash --device 5i25 --write 5i25_g540x2.bit
sudo mesaflash --device 5i25 --reload
Last edit: 5 years 11 months ago by PCW.
The following user(s) said Thank You: kevin19
5 years 11 months ago - 5 years 11 months ago #188482 by kevin19
Replied by kevin19 on topic pncconfig error
thank you for your help:)
Last edit: 5 years 11 months ago by kevin19.
5 years 11 months ago #188508 by kevin19
I do have a question concerning the step, dir,enable, reset, fullstep, and fault output functions of my 4 gecko drivers. Mechanically I have connected them to the db25F connector(P3) and HDR26 connector(P2), but how and where should I configure them in pncconf?
5 years 11 months ago #188518 by PCW
Did you select g540x2 and the press "Accept components Changes"
Do you have a 7I75 in between?
5 years 11 months ago - 5 years 11 months ago #188520 by kevin19
Yes, I did press "accept components changes". I use the 7i75 breakout board for step, dir, enable functions and limit switches and hdr26 breakout board for the other functions as you can see in my wiring diagram.
5 years 11 months ago #188521 by PCW
Does the I/O connector 3 tab show the stepgen pins?
Time to create page: 0.278 seconds
