- Thank you received: 32
[SOLVED] Mesa 7i80HD-16: startup errors
- travis036
5 years 10 months ago #191730
by travis036
Replied by travis036 on topic Mesa 7i80HD-16: startup errors
- Thank you received: 5334
5 years 10 months ago #191732
Replied by PCW on topic Mesa 7i80HD-16: startup errors
Right but that does not mean you have the correct firmware installed in the 7I80
What does:
mesaflash --device 7i80hd --readhmid
report?
What does:
report?
- travis036
5 years 10 months ago #191733
by travis036
i think i assumed that the pncconf flashed the FPGA... how do i flash the FPGA card?
~Travis
~Travis
5 years 10 months ago #191735
with mesaflash
- travis036
5 years 10 months ago #191736
by travis036
couldn't find mesaflash on my linuxcnc machine. downloaded it from Mesa, but it is windows, so i booted my windows machine, and tried the command, but it didn't like it. i did manage this though, if it is the correct info.
~Travis
./mesaflash.exe --device 7i80 --rpo 192.168.1.121 --verbose
board name: 7I80HD-16
LBP16 address spaces:
0: HostMot2 (registers, RW, 32-bit) [size=64K]
1: KSZ8851 (registers, RW, 16-bit) [size=256]
2: EtherEEP (EEPROM, RW, 16-bit) [size=128], page size: 0x1, erase size: 0x1
3: FPGAFlsh (flash, RW, 32-bit) [size=16M], page size: 0x100, erase size: 0x10000
6: LBP16RW (memory, RW, 16-bit) [size=16]
7: LBP16RO (memory, RO, 16-bit) [size=16]
eth eeprom info:
mac address: 00:60:1B:11:81:5D
ip address: 192.168.1.121
user leds: eth debug
FPGA flash eeprom info:
flash id: 0x14 (size 16Mb)
lba16 status/control info:
packets recived: all 63153, UDP 3964, bad 0
packets sended: all 3523, UDP 3508, bad 0
parse errors: 0, mem errors 0, write errors 0
UDP time: 0
board info:
LBP16 version 3
firmware version 15
IP address jumpers at boot: fixed 192.168.1.121
firmware info:
cookie: 55AACAFE
IDROM version: 3
Module 0: Watchdog, version 0 [instances=1]
Module 1: IOPort, version 0 [instances=3]
Module 2: Muxed Encoder, version 3 [instances=6]
Module 3: Muxed Encoder Select, version 0 [instances=1]
Module 4: PWMGen, version 0 [instances=6]
Module 5: Smart Serial Interface, version 0 [instances=1]
Module 6: LED, version 0 [instances=1]
0xFFFFFFFF
~Travis
- travis036
5 years 10 months ago #191741
by travis036
ok, now what? (sorry for being fairly clueless)
~Travis
./mesaflash.exe --device 7i80 --ip 192.168.1.121 --verbose --write ./7i80hd_16_st12.bit
eth eeprom info:
packets recived: all 64530, UDP 4015, bad 0
packets sended: all 3575, UDP 3559, bad 0
UDP time: 0
board info:
LBP16 version 3
firmware version 15
firmware info:
cookie: 55AACAFE
IDROM version: 3
Checking file... OK
File type: BIT file
Design name: TopEthernetHostMot2b.ncd;UserID=0xFFFFFFFF
Part name: 6slx16ftg256
Design date: 2014/09/14
Design time: 18:27:46
Config Length: 464196
Boot sector OK
EEPROM sectors to write: 7, max sectors in area: 16
Erasing EEPROM sectors starting from 0x100000...
|EEEEEEEE
Programming EEPROM sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration verified successfully
~Travis
Time to create page: 2.920 seconds
