new pnc.config won't load in linuxcnc
- mjones@welfab.ca
- Thank you received: 6
22 Jul 2021 16:15 - 22 Jul 2021 16:15 #215601
by mjones@welfab.ca
Replied by mjones@welfab.ca on topic new pnc.config won't load in linuxcnc
Im an idiot. A friend told me what boards to get, I didn't realize that the 7i76E was meant to connect only with eithernet and hooked it up like a 7i76. now i will have to hook it up through eithernet and figure out how to configure the connection, or get a 7i76. If i use eithernet hook up then i loose the internet connection. next question is, can the 7i77 and 7i76E run together?
Last edit: 22 Jul 2021 16:15 by mjones@welfab.ca.
- Thank you received: 5328
22 Jul 2021 16:36 #215603
Replied by PCW on topic new pnc.config won't load in linuxcnc
Thought you have been talking about a 6I25 +7I77_7I76
A 7I76E is an Ethernet connected card unrelated to a 6I25
- Thank you received: 7487
22 Jul 2021 16:39 #215604
Nope.
Replied by tommylight on topic new pnc.config won't load in linuxcnc
its a 7i76E im sure i put that at the beggining
Nope.
- mjones@welfab.ca
22 Jul 2021 16:40 #215606
by mjones@welfab.ca
sorry for the confusion, i have to stop being lazy and missing digits out. i guess i will have to buy a 7i76 board and start all over.
Thanks for you time and effort. I really appreciate it.
22 Jul 2021 16:42 #215607
Yes, there is 7I76E firmware to run with an attached 7I77
You can run a LinuxCNC real time Ethernet connection using the motherboard
Ethernet and just ad a USB WIFI or Ethernet dongle for internet access.
- mjones@welfab.ca
22 Jul 2021 18:48 #215609
by mjones@welfab.ca
i had already ordered the 7i76 before i seen this response. it will likely take 2 or more weeks to get it so i will probably try to figure out how to connect and load firmware while waiting.
22 Jul 2021 19:01 #215611
If it was ordered from Mesa and not shipped yet, we can cancel the order if you wish
- mjones@welfab.ca
24 Jul 2021 16:47 #215791
by mjones@welfab.ca
Ok. I wasn't able to do anything with this yesterday, had to work on site. I now have connected the 7i76e through eithernet and can ping it. but now i have no idea how to do a pnc.config as it doesnt give an eithernet option, only pci and parallel options. I am still running the 7i77 and 7i64 through the 6i25 but trying to run the 7i76e through eithernet. is this wrong should i connect the 7i77 and 7i64 to the 7i76e and run it all on eithernet? either way i need to know how to make a hal file to connect to the 7i76e,
24 Jul 2021 17:21 #215796
Pncconf can setup a Ethernet connected 7I76E but I don't think it can setup a 7I77
daughters card attached to a 7I76E.
You could use a 5i25 /7i76/7i77 configuration and edit the hal file to change the driver
command line from hm2_pci to hm2_eth, add the ip address in the driver
command line, and change the card name from 5i25 to 7i76e in the ini file
- mjones@welfab.ca
24 Jul 2021 17:26 #215797
by mjones@welfab.ca
would i have to reflash the 6i25 for the 5i25-7i76/7i77 configuration?
Time to create page: 0.181 seconds
