new pnc.config won't load in linuxcnc
- Thank you received: 5314
24 Jul 2021 17:28 #215798
Replied by PCW on topic new pnc.config won't load in linuxcnc
You would have to reflash the 7I76E with firmware that supports a 7I77
- mjones@welfab.ca
- Thank you received: 6
25 Jul 2021 14:24 #215858
by mjones@welfab.ca
Replied by mjones@welfab.ca on topic new pnc.config won't load in linuxcnc
im having a proplem getting the
cd to ~/configs/hostmot2/
command to work, i remember having a problem last time but i ran through all the files it had to go to to get there and got it to work but can't get it to work now.
25 Jul 2021 14:43 #215859
Sorry, I forgot t include the card name in the path.
If you unzipped the 7i76e.zip file in your home directory it would be:
cd ~/7i76e/configs/hostmot2
- mjones@welfab.ca
25 Jul 2021 15:07 #215860
by mjones@welfab.ca
ok, i know im being a pain. i managed to reflash the 6i25 to 7i76_7i77. but trying to reflash the 7i76e it says board not found. i can ping it at 10.10.10.10and get responce but my network connection must be wrong some how.
25 Jul 2021 15:26 #215863
If you can ping 10.10.10.10 but you get a "board not found" error
it usually means you have set the PC's IP address to 10.10.10.10
(instead of say 10.10.10.100)
( so you are pinging the PC )
- mjones@welfab.ca
25 Jul 2021 15:36 #215864
by mjones@welfab.ca
well i just followed one of the tutorials on the forum and now i have no networks, i had to go to my windows pc to respond. i will have to get connection 1 working first for internet, then figure out connection 2. i didn't change anything in connection 1 but now i lost it.
- mjones@welfab.ca
25 Jul 2021 15:51 #215866
by mjones@welfab.ca
i rebooted the computer, now connection 1 works and connection 2 although says not connected, i can ping the 7i76e and the mesaflash readhmid comand spits info out, now i should be able to reflash it. one question, the 7i77 should i connect that to the 7i76e through the expansion port1 through the db25 on the 7i77
25 Jul 2021 16:31 #215880
Yes, 7I76E P1 to 7I77 with HDR26 --> DB25M cable
- mjones@welfab.ca
25 Jul 2021 16:38 #215884
by mjones@welfab.ca
i still am unable to get a 7i76e in the pnccongif, nor can i get a 7i76_7i77 option i reflashed the 6i25 to 5i25_7i76_7i77.bit .. if i use the 7i76e with eithernet hook up then i shouldn't even need the 6i25, but i would have to be able to get the pnc.config wizard to give me that option. other wise i would have to figure out how to get pnc.config to offer the 7i76_7i77 option, set that up then edit everything in hal. if i understood the code strings better i could just make the hole thing myself, but far to new to this for that.
25 Jul 2021 17:16 - 25 Jul 2021 17:18 #215888
1. pncconf supports the 7I76E, at least the current version does (in 2.8.2)
2. The 7I76E option in pncconf does not support an added 7I77 so
it probably easiest to create a 7I76/7I77 config for a 5I25 and do the minor
edits in the hal/ini files to change the base FPGA card to a 7I76E
Last edit: 25 Jul 2021 17:18 by PCW.
Time to create page: 0.676 seconds
