new pnc.config won't load in linuxcnc
5 years 3 months ago #215437 by mjones@welfab.ca
I'm sure this is a common problem.  I have mesa 5i25-7i77 in pci1-7i76 in pci2-and 7i64 serial(rj45) to 7i77 rs-422 expansion tb6.  After running through pnc.config. i tried opening the configuration in linuxcnc, and it just poped up the an error.  very lengthy error report so i apologize for the length.  I was hoping someone out there thats smarter then i am could tell me what is wrong with the configuration.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.15
Machine configuration directory is '/home/hard/linuxcnc/configs/SuperSlant'
Machine configuration file is 'SuperSlant.ini'
INIFILE=/home/hard/linuxcnc/configs/SuperSlant/SuperSlant.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
CANNOT FIND FILE FOR:BigGrayBeast.hal
Debug file information:
4420
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[    0.000000]  BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 00000000daf0a000 (usable)
[    0.000000]  BIOS-e820: 00000000daf0a000 - 00000000db000000 (reserved)
[    0.000000]  BIOS-e820: 00000000db000000 - 00000000db74e000 (usable)
[    0.000000]  BIOS-e820: 00000000db74e000 - 00000000db800000 (reserved)
[    0.000000]  BIOS-e820: 00000000db800000 - 00000000dbfb4000 (usable)
[    0.000000]  BIOS-e820: 00000000dbfb4000 - 00000000dc000000 (ACPI data)
[    0.000000]  BIOS-e820: 00000000dc000000 - 00000000dd70e000 (usable)
[    0.000000]  BIOS-e820: 00000000dd70e000 - 00000000dd800000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dd800000 - 00000000deee1000 (usable)
[    0.000000]  BIOS-e820: 00000000deee1000 - 00000000df0df000 (reserved)
[    0.000000]  BIOS-e820: 00000000df0df000 - 00000000df122000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000df122000 - 00000000df800000 (usable)
[    0.000000]  BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[    0.000000]  BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[    0.000000]  BIOS-e820: 0000000100000000 - 000000041e000000 (usable)
[    0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Dell Inc. OptiPlex 7010/0773VG, BIOS A13 03/25/2013
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] last_pfn = 0xdf800 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-D3FFF write-protect
[    0.000000]   D4000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask C00000000 write-back
[    0.000000]   1 base 400000000 mask FF0000000 write-back
[    0.000000]   2 base 410000000 mask FF8000000 write-back
[    0.000000]   3 base 418000000 mask FFC000000 write-back
[    0.000000]   4 base 41C000000 mask FFE000000 write-back
[    0.000000]   5 base 0E0000000 mask FE0000000 uncachable
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820 update range: 00000000e0000000 - 0000000100000000 (usable) ==> (reserved)
[    0.000000] found SMP MP-table at [c00fda80] fda80
[    0.000000] initial memory mapped : 0 - 01800000
[    0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[    0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 0037400000 page 2M
[    0.000000]  0037400000 - 00377fe000 page 4k
[    0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[    0.000000] RAMDISK: 36410000 - 37200000
[    0.000000] ACPI: RSDP 000ee080 00024 (v02 DELL  )
[    0.000000] ACPI: XSDT dbff4080 0007C (v01 DELL    CBX3    01072009 AMI  00010013)
[    0.000000] ACPI: FACP dbffd7b0 0010C (v05 DELL    CBX3    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT dbff4188 09625 (v02 DELL    CBX3    00000022 INTL 20091112)
[    0.000000] ACPI: FACS dd7fe080 00040
[    0.000000] ACPI: APIC dbffd8c0 00072 (v03 DELL    CBX3    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT dbffd938 00044 (v01 DELL    CBX3    01072009 AMI  00010013)
[    0.000000] ACPI: MCFG dbffd980 0003C (v01 DELL    CBX3    01072009 MSFT 00000097)
[    0.000000] ACPI: HPET dbffd9c0 00038 (v01 DELL    CBX3    01072009 AMI. 00000005)
[    0.000000] ACPI: SSDT dbffd9f8 00415 (v01 SataRe SataTabl 00001000 INTL 20091112)
[    0.000000] ACPI: SSDT dbffde10 009B9 (v01  PmRef  Cpu0Ist 00003000 INTL 20051117)
[    0.000000] ACPI: SSDT dbffe7d0 00A92 (v01  PmRef    CpuPm 00003000 INTL 20051117)
[    0.000000] ACPI: DMAR dbfff268 00080 (v01 INTEL      SNB  00000001 INTL 00000001)
[    0.000000] ACPI: ASF! dbfff2e8 000A5 (v32 INTEL       HCG 00000001 TFSM 000F4240)
[    0.000000] ACPI: SLIC dbfff390 00176 (v03 DELL    CBX3    01072009 MSFT 00010013)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 2688MB HIGHMEM available.
[    0.000000] 887MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 377fe000
[    0.000000]   low ram: 0 - 377fe000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x000377fe
[    0.000000]   HighMem  0x000377fe -> 0x000df800
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009d
[    0.000000]     0: 0x00000100 -> 0x000daf0a
[    0.000000]     0: 0x000db000 -> 0x000db74e
[    0.000000]     0: 0x000db800 -> 0x000dbfb4
[    0.000000]     0: 0x000dc000 -> 0x000dd70e
[    0.000000]     0: 0x000dd800 -> 0x000deee1
[    0.000000]     0: 0x000df122 -> 0x000df800
[    0.000000] On node 0 totalpages: 914022
[    0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4820200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3949 pages, LIFO batch:0
[    0.000000]   Normal zone: 1744 pages used for memmap
[    0.000000]   Normal zone: 221486 pages, LIFO batch:31
[    0.000000]   HighMem zone: 5377 pages used for memmap
[    0.000000]   HighMem zone: 681434 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[    0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[    0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[    0.000000] Allocating PCI resources starting at df800000 (gap: df800000:18800000)
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[    0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 906869
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=9ced5b65-7026-4bca-8241-ab8a8def232c ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[    0.000000] allocated 7323520 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (000377fe:000df800)
[    0.000000] Memory: 3599044k/3661824k available (3495k kernel code, 57044k reserved, 1237k data, 416k init, 2747244k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff17000 - 0xfffff000   ( 928 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xf7ffe000 - 0xff7fe000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf77fe000   ( 887 MB)
[    0.000000]       .init : 0xc14a0000 - 0xc1508000   ( 416 kB)
[    0.000000]       .data : 0xc1369d4a - 0xc149f480   (1237 kB)
[    0.000000]       .text : 0xc1000000 - 0xc1369d4a   (3495 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:2304 nr_irqs:712 16
[    0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[    0.000000] Extended CMOS year: 2000
[    0.000000] Interrupt pipeline (release #3)
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration using PIT
[    0.004000] Detected 3392.191 MHz processor.
[    0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6784.38 BogoMIPS (lpj=13568764)
[    0.000003] pid_max: default: 32768 minimum: 301
[    0.000027] Security Framework initialized
[    0.000030] AppArmor: AppArmor disabled by boot time parameter
[    0.000040] Mount-cache hash table entries: 512
[    0.000149] Initializing cgroup subsys cpuacct
[    0.000151] Initializing cgroup subsys memory
[    0.000154] Initializing cgroup subsys devices
[    0.000156] Initializing cgroup subsys freezer
[    0.000157] Initializing cgroup subsys net_cls
[    0.000158] Initializing cgroup subsys blkio
[    0.000161] Initializing cgroup subsys perf_event
[    0.000179] CPU: Physical Processor ID: 0
[    0.000180] CPU: Processor Core ID: 0
[    0.000183] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.000183] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.000705] mce: CPU supports 9 MCE banks
[    0.000715] CPU0: Thermal monitoring enabled (TM1)
[    0.000785] ACPI: Core revision 20120320
[    0.005176] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.005578] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.045148] CPU0: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz stepping 09
[    0.152581] Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver.
[    0.152587] ... version:                3
[    0.152588] ... bit width:              48
[    0.152589] ... generic registers:      8
[    0.152590] ... value mask:             0000ffffffffffff
[    0.152591] ... max period:             000000007fffffff
[    0.152592] ... fixed-purpose events:   3
[    0.152593] ... event mask:             00000007000000ff
[    0.164600] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.176530] CPU 1 irqstacks, hard=f3cf6000 soft=f3cf8000
[    0.176532] Booting Node   0, Processors  #1
[    0.186778] Initializing CPU#1
[    0.190138] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.196476] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[    0.196479]  #2
[    0.206663] Initializing CPU#2
[    0.210081] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.216417] CPU 3 irqstacks, hard=f3d1c000 soft=f3d1e000
[    0.216420]  #3 Ok.
[    0.226604] Initializing CPU#3
[    0.230023] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.230046] Brought up 4 CPUs
[    0.230047] Total of 4 processors activated (27137.52 BogoMIPS).
[    0.232204] devtmpfs: initialized
[    0.232346] PM: Registering ACPI NVS region [mem 0xdd70e000-0xdd7fffff] (991232 bytes)
[    0.232371] PM: Registering ACPI NVS region [mem 0xdf0df000-0xdf121fff] (274432 bytes)
[    0.232434] dummy:
[    0.232470] NET: Registered protocol family 16
[    0.232544] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.232546] ACPI: bus type pci registered
[    0.232581] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.232583] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.232584] PCI: Using MMCONFIG for extended config space
[    0.232586] PCI: Using configuration type 1 for base access
[    0.232593] dmi type 0xB1 record - unknown flag
[    0.232960] bio: create slab <bio-0> at 0
[    0.233019] ACPI: Added _OSI(Module Device)
[    0.233020] ACPI: Added _OSI(Processor Device)
[    0.233022] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.233023] ACPI: Added _OSI(Processor Aggregator Device)
[    0.234469] ACPI: EC: Look up EC in DSDT
[    0.236006] ACPI: Executed 1 blocks of module-level executable AML code
[    0.239058] ACPI: SSDT df086018 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20051117)
[    0.239438] ACPI: Dynamic OEM Table Load:
[    0.239440] ACPI: SSDT   (null) 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20051117)
[    0.239669] ACPI: SSDT df087a98 00303 (v01  PmRef    ApIst 00003000 INTL 20051117)
[    0.240079] ACPI: Dynamic OEM Table Load:
[    0.240081] ACPI: SSDT   (null) 00303 (v01  PmRef    ApIst 00003000 INTL 20051117)
[    0.240189] ACPI: SSDT df08dc18 00119 (v01  PmRef    ApCst 00003000 INTL 20051117)
[    0.240565] ACPI: Dynamic OEM Table Load:
[    0.240567] ACPI: SSDT   (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20051117)
[    0.241063] ACPI: Interpreter enabled
[    0.241068] ACPI: (supports S0 S3 S4 S5)
[    0.241086] ACPI: Using IOAPIC for interrupt routing
[    0.246639] ACPI: No dock devices found.
[    0.246642] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.246895] \_SB_.PCI0:_OSC invalid UUID
[    0.246896] _OSC request data:1 8 0
[    0.246900] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.247286] pci_root PNP0A08:00: host bridge window [io  0x0000-0x0cf7]
[    0.247288] pci_root PNP0A08:00: host bridge window [io  0x0d00-0xffff]
[    0.247289] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[    0.247291] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[    0.247292] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[    0.247294] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[    0.247295] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[    0.247297] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[    0.247298] pci_root PNP0A08:00: host bridge window [mem 0xe0000000-0xfeafffff]
[    0.247320] PCI host bridge to bus 0000:00
[    0.247321] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7]
[    0.247323] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff]
[    0.247324] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[    0.247326] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[    0.247327] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[    0.247328] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[    0.247330] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[    0.247331] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[    0.247333] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff]
[    0.247340] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[    0.247368] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[    0.247388] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.247428] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[    0.247450] pci 0000:00:14.0: reg 10: [mem 0xf7f20000-0xf7f2ffff 64bit]
[    0.247505] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.247526] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[    0.247548] pci 0000:00:16.0: reg 10: [mem 0xf7f3c000-0xf7f3c00f 64bit]
[    0.247607] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.247631] pci 0000:00:16.3: [8086:1e3d] type 00 class 0x070002
[    0.247648] pci 0000:00:16.3: reg 10: [io  0xf0a0-0xf0a7]
[    0.247657] pci 0000:00:16.3: reg 14: [mem 0xf7f3a000-0xf7f3afff]
[    0.247738] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
[    0.247754] pci 0000:00:19.0: reg 10: [mem 0xf7f00000-0xf7f1ffff]
[    0.247762] pci 0000:00:19.0: reg 14: [mem 0xf7f39000-0xf7f39fff]
[    0.247771] pci 0000:00:19.0: reg 18: [io  0xf040-0xf05f]
[    0.247817] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    0.247841] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[    0.247861] pci 0000:00:1a.0: reg 10: [mem 0xf7f38000-0xf7f383ff]
[    0.247931] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.247955] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[    0.247968] pci 0000:00:1b.0: reg 10: [mem 0xf7f30000-0xf7f33fff 64bit]
[    0.248020] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.248045] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[    0.248143] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.248177] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
[    0.248236] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.248266] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[    0.248286] pci 0000:00:1d.0: reg 10: [mem 0xf7f37000-0xf7f373ff]
[    0.248356] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.248375] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.248429] pci 0000:00:1f.0: [8086:1e47] type 00 class 0x060100
[    0.248537] pci 0000:00:1f.2: [8086:1e02] type 00 class 0x010601
[    0.248555] pci 0000:00:1f.2: reg 10: [io  0xf090-0xf097]
[    0.248562] pci 0000:00:1f.2: reg 14: [io  0xf080-0xf083]
[    0.248569] pci 0000:00:1f.2: reg 18: [io  0xf070-0xf077]
[    0.248577] pci 0000:00:1f.2: reg 1c: [io  0xf060-0xf063]
[    0.248584] pci 0000:00:1f.2: reg 20: [io  0xf020-0xf03f]
[    0.248592] pci 0000:00:1f.2: reg 24: [mem 0xf7f36000-0xf7f367ff]
[    0.248623] pci 0000:00:1f.2: PME# supported from D3hot
[    0.248640] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[    0.248654] pci 0000:00:1f.3: reg 10: [mem 0xf7f35000-0xf7f350ff 64bit]
[    0.248674] pci 0000:00:1f.3: reg 20: [io  0xf000-0xf01f]
[    0.248722] pci 0000:01:00.0: [1002:6778] type 00 class 0x030000
[    0.248734] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.248744] pci 0000:01:00.0: reg 18: [mem 0xf7e20000-0xf7e3ffff 64bit]
[    0.248751] pci 0000:01:00.0: reg 20: [io  0xe000-0xe0ff]
[    0.248763] pci 0000:01:00.0: reg 30: [mem 0xf7e00000-0xf7e1ffff pref]
[    0.248780] pci 0000:01:00.0: supports D1 D2
[    0.248801] pci 0000:01:00.1: [1002:aa98] type 00 class 0x040300
[    0.248813] pci 0000:01:00.1: reg 10: [mem 0xf7e40000-0xf7e43fff 64bit]
[    0.248855] pci 0000:01:00.1: supports D1 D2
[    0.257945] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    0.257950] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.257954] pci 0000:00:01.0:   bridge window [mem 0xf7e00000-0xf7efffff]
[    0.257960] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[    0.258045] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    0.258136] pci 0000:03:00.0: [104c:8240] type 01 class 0x060400
[    0.258278] pci 0000:03:00.0: supports D1 D2
[    0.265927] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[    0.265937] pci 0000:00:1c.4:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.266085] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[    0.266113] pci 0000:04:00.0: reg 10: [mem 0xf7d00000-0xf7d0ffff]
[    0.266338] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[    0.266354] pci 0000:03:00.0:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.266434] pci 0000:00:1e.0: PCI bridge to [bus 05-05] (subtractive decode)
[    0.266443] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7] (subtractive decode)
[    0.266445] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff] (subtractive decode)
[    0.266446] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[    0.266448] pci 0000:00:1e.0:   bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[    0.266449] pci 0000:00:1e.0:   bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[    0.266451] pci 0000:00:1e.0:   bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[    0.266452] pci 0000:00:1e.0:   bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[    0.266454] pci 0000:00:1e.0:   bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[    0.266456] pci 0000:00:1e.0:   bridge window [mem 0xe0000000-0xfeafffff] (subtractive decode)
[    0.266475] pci_bus 0000:00: on NUMA node 0
[    0.266478] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.266625] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[    0.266705] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[    0.266741] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[    0.266776] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[    0.266868] \_SB_.PCI0:_OSC invalid UUID
[    0.266869] _OSC request data:1 f 0
[    0.266872]  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[    0.271145] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.271185] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.271223] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.271260] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.271299] ACPI: PCI Interrupt Link [LNKE] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.271337] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.271375] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.271412] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.271468] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.271471] vgaarb: loaded
[    0.271472] vgaarb: bridge control possible 0000:01:00.0
[    0.271487] PCI: Using ACPI for IRQ routing
[    0.272901] PCI: pci_cache_line_size set to 64 bytes
[    0.272980] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[    0.272982] reserve RAM buffer: 00000000daf0a000 - 00000000dbffffff
[    0.272984] reserve RAM buffer: 00000000db74e000 - 00000000dbffffff
[    0.272985] reserve RAM buffer: 00000000dbfb4000 - 00000000dbffffff
[    0.272987] reserve RAM buffer: 00000000dd70e000 - 00000000dfffffff
[    0.272988] reserve RAM buffer: 00000000deee1000 - 00000000dfffffff
[    0.272990] reserve RAM buffer: 00000000df800000 - 00000000dfffffff
[    0.273071] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.273076] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.275088] Switching to clocksource hpet
[    0.275129] pnp: PnP ACPI init
[    0.275134] ACPI: bus type pnp registered
[    0.275343] pnp 00:00: [bus 00-3e]
[    0.275345] pnp 00:00: [io  0x0000-0x0cf7 window]
[    0.275347] pnp 00:00: [io  0x0cf8-0x0cff]
[    0.275348] pnp 00:00: [io  0x0d00-0xffff window]
[    0.275349] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    0.275351] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[    0.275352] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[    0.275354] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[    0.275356] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[    0.275357] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[    0.275359] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[    0.275360] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[    0.275361] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[    0.275363] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[    0.275364] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[    0.275366] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[    0.275367] pnp 00:00: [mem 0x000ec000-0x000effff window]
[    0.275368] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[    0.275370] pnp 00:00: [mem 0xe0000000-0xfeafffff window]
[    0.275371] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[    0.275404] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[    0.275420] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[    0.275442] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.275444] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.275451] pnp 00:02: [io  0x0000-0x001f]
[    0.275453] pnp 00:02: [io  0x0081-0x0091]
[    0.275454] pnp 00:02: [io  0x0093-0x009f]
[    0.275455] pnp 00:02: [io  0x00c0-0x00df]
[    0.275457] pnp 00:02: [dma 4]
[    0.275468] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.275474] pnp 00:03: [mem 0xff000000-0xffffffff]
[    0.275487] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[    0.275538] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[    0.275551] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[    0.275559] pnp 00:05: [io  0x002e-0x002f]
[    0.275561] pnp 00:05: [io  0x004e-0x004f]
[    0.275562] pnp 00:05: [io  0x0061]
[    0.275563] pnp 00:05: [io  0x0063]
[    0.275564] pnp 00:05: [io  0x0065]
[    0.275565] pnp 00:05: [io  0x0067]
[    0.275566] pnp 00:05: [io  0x0070]
[    0.275567] pnp 00:05: [io  0x0080]
[    0.275569] pnp 00:05: [io  0x0092]
[    0.275570] pnp 00:05: [io  0x00b2-0x00b3]
[    0.275571] pnp 00:05: [io  0x0680-0x069f]
[    0.275572] pnp 00:05: [io  0x1000-0x100f]
[    0.275573] pnp 00:05: [io  0xffff]
[    0.275575] pnp 00:05: [io  0xffff]
[    0.275576] pnp 00:05: [io  0x0400-0x0453]
[    0.275577] pnp 00:05: [io  0x0458-0x047f]
[    0.275578] pnp 00:05: [io  0x0500-0x057f]
[    0.275579] pnp 00:05: [io  0x164e-0x164f]
[    0.275604] system 00:05: [io  0x0680-0x069f] has been reserved
[    0.275605] system 00:05: [io  0x1000-0x100f] has been reserved
[    0.275607] system 00:05: [io  0xffff] has been reserved
[    0.275609] system 00:05: [io  0xffff] has been reserved
[    0.275610] system 00:05: [io  0x0400-0x0453] has been reserved
[    0.275612] system 00:05: [io  0x0458-0x047f] has been reserved
[    0.275613] system 00:05: [io  0x0500-0x057f] has been reserved
[    0.275615] system 00:05: [io  0x164e-0x164f] has been reserved
[    0.275617] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.275622] pnp 00:06: [io  0x0070-0x0077]
[    0.275628] pnp 00:06: [irq 8]
[    0.275642] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.275662] pnp 00:07: [io  0x0454-0x0457]
[    0.275684] system 00:07: [io  0x0454-0x0457] has been reserved
[    0.275685] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.275743] pnp 00:08: [io  0x0000-0xffffffff disabled]
[    0.275744] pnp 00:08: [io  0x0a40-0x0a4f]
[    0.275745] pnp 00:08: [io  0x0a00-0x0a3f]
[    0.275767] system 00:08: [io  0x0a40-0x0a4f] has been reserved
[    0.275769] system 00:08: [io  0x0a00-0x0a3f] has been reserved
[    0.275771] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.275786] pnp 00:09: [io  0x0010-0x001f]
[    0.275787] pnp 00:09: [io  0x0022-0x003f]
[    0.275788] pnp 00:09: [io  0x0044-0x005f]
[    0.275789] pnp 00:09: [io  0x0062-0x0063]
[    0.275791] pnp 00:09: [io  0x0065-0x006f]
[    0.275792] pnp 00:09: [io  0x0072-0x007f]
[    0.275793] pnp 00:09: [io  0x0080]
[    0.275794] pnp 00:09: [io  0x0084-0x0086]
[    0.275795] pnp 00:09: [io  0x0088]
[    0.275796] pnp 00:09: [io  0x008c-0x008e]
[    0.275798] pnp 00:09: [io  0x0090-0x009f]
[    0.275799] pnp 00:09: [io  0x00a2-0x00bf]
[    0.275800] pnp 00:09: [io  0x00e0-0x00ef]
[    0.275802] pnp 00:09: [io  0x04d0-0x04d1]
[    0.275827] system 00:09: [io  0x04d0-0x04d1] has been reserved
[    0.275829] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.275834] pnp 00:0a: [io  0x00f0-0x00ff]
[    0.275838] pnp 00:0a: [irq 13]
[    0.275852] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.276669] pnp 00:0b: [io  0x03f8-0x03ff]
[    0.276673] pnp 00:0b: [irq 4]
[    0.276674] pnp 00:0b: [dma 0 disabled]
[    0.276707] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.276884] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[    0.276885] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[    0.276886] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[    0.276888] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[    0.276889] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[    0.276890] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[    0.276892] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[    0.276893] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[    0.276894] pnp 00:0c: [mem 0xff000000-0xffffffff]
[    0.276896] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[    0.276897] pnp 00:0c: [mem 0xf0000000-0xf0000fff]
[    0.276937] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.276939] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.276941] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.276942] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.276944] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.276946] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.276948] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.276949] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.276951] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[    0.276953] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.276955] system 00:0c: [mem 0xf0000000-0xf0000fff] has been reserved
[    0.276957] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.277058] pnp: PnP ACPI: found 13 devices
[    0.277059] ACPI: ACPI bus type pnp unregistered
[    0.277061] PnPBIOS: Disabled by ACPI PNP
[    0.312828] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    0.312831] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.312833] pci 0000:00:01.0:   bridge window [mem 0xf7e00000-0xf7efffff]
[    0.312835] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[    0.312839] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    0.312856] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[    0.312864] pci 0000:03:00.0:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.312880] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[    0.312886] pci 0000:00:1c.4:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.312893] pci 0000:00:1e.0: PCI bridge to [bus 05-05]
[    0.312939] pci 0000:00:1e.0: setting latency timer to 64
[    0.312943] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
[    0.312944] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
[    0.312946] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    0.312947] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff]
[    0.312949] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff]
[    0.312950] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff]
[    0.312952] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000e3fff]
[    0.312953] pci_bus 0000:00: resource 11 [mem 0x000e4000-0x000e7fff]
[    0.312955] pci_bus 0000:00: resource 12 [mem 0xe0000000-0xfeafffff]
[    0.312956] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.312957] pci_bus 0000:01: resource 1 [mem 0xf7e00000-0xf7efffff]
[    0.312959] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[    0.312961] pci_bus 0000:03: resource 1 [mem 0xf7d00000-0xf7dfffff]
[    0.312962] pci_bus 0000:04: resource 1 [mem 0xf7d00000-0xf7dfffff]
[    0.312964] pci_bus 0000:05: resource 4 [io  0x0000-0x0cf7]
[    0.312965] pci_bus 0000:05: resource 5 [io  0x0d00-0xffff]
[    0.312966] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff]
[    0.312968] pci_bus 0000:05: resource 7 [mem 0x000d4000-0x000d7fff]
[    0.312969] pci_bus 0000:05: resource 8 [mem 0x000d8000-0x000dbfff]
[    0.312971] pci_bus 0000:05: resource 9 [mem 0x000dc000-0x000dffff]
[    0.312972] pci_bus 0000:05: resource 10 [mem 0x000e0000-0x000e3fff]
[    0.312974] pci_bus 0000:05: resource 11 [mem 0x000e4000-0x000e7fff]
[    0.312975] pci_bus 0000:05: resource 12 [mem 0xe0000000-0xfeafffff]
[    0.313035] NET: Registered protocol family 2
[    0.313072] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.313179] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.313301] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.313354] TCP: Hash tables configured (established 131072 bind 65536)
[    0.313356] TCP: reno registered
[    0.313357] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.313360] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.313410] NET: Registered protocol family 1
[    0.354902] pci 0000:01:00.0: Boot video device
[    0.354918] PCI: CLS 64 bytes, default 64
[    0.354951] Unpacking initramfs...
[    0.540434] Freeing initrd memory: 14272k freed
[    0.541962] audit: initializing netlink socket (disabled)
[    0.541970] type=2000 audit(1626805274.432:1): initialized
[    0.550295] highmem bounce pool size: 64 pages
[    0.550305] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    0.550463] VFS: Disk quotas dquot_6.5.2
[    0.550481] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.550527] msgmni has been set to 1691
[    0.550636] alg: No test for stdrng (krng)
[    0.550656] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.550658] io scheduler noop registered
[    0.550659] io scheduler deadline registered
[    0.550677] io scheduler cfq registered (default)
[    0.550862] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.550872] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.550873] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.551186] GHES: HEST is not enabled!
[    0.551193] isapnp: Scanning for PnP cards...
[    0.904192] isapnp: No Plug & Play device found
[    0.904222] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.924826] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.945643] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.965871] 0000:00:16.3: ttyS1 at I/O 0xf0a0 (irq = 19) is a 16550A
[    0.966029] Linux agpgart interface v0.103
[    0.966173] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.969078] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.969095] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.969168] mousedev: PS/2 mouse device common for all mice
[    0.969198] rtc_cmos 00:06: RTC can wake from S4
[    0.969304] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[    0.969331] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.969405] TCP: cubic registered
[    0.969457] NET: Registered protocol family 10
[    0.969591] Mobile IPv6
[    0.969593] NET: Registered protocol family 17
[    0.969595] Registering the dns_resolver key type
[    0.969628] Using IPI No-Shortcut mode
[    0.969694] PM: Hibernation image not present or could not be loaded.
[    0.969700] registered taskstats version 1
[    0.970026] rtc_cmos 00:06: setting system clock to 2021-07-20 18:21:15 UTC (1626805275)
[    0.970104] Freeing unused kernel memory: 416k freed
[    0.970186] Write protecting the kernel text: 3496k
[    0.970201] Write protecting the kernel read-only data: 984k
[    0.976978] udevd[58]: starting version 175
[    0.987612] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[    0.987614] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[    0.987648] e1000e 0000:00:19.0: setting latency timer to 64
[    0.987702] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    0.987727] usbcore: registered new interface driver usbfs
[    0.987739] usbcore: registered new interface driver hub
[    0.989460] usbcore: registered new device driver usb
[    0.989658] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.990880] SCSI subsystem initialized
[    0.991857] libata version 3.00 loaded.
[    0.993537] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x16
[    1.005436] microcode: CPU0 updated to revision 0x1b, date = 2014-05-29
[    1.005443] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x16
[    1.006981] microcode: CPU1 updated to revision 0x1b, date = 2014-05-29
[    1.006986] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x16
[    1.008423] microcode: CPU2 updated to revision 0x1b, date = 2014-05-29
[    1.008432] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x16
[    1.009897] microcode: CPU3 updated to revision 0x1b, date = 2014-05-29
[    1.009927] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.245158] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) b8:ca:3a:7e:98:fb
[    1.245160] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[    1.245195] e1000e 0000:00:19.0: eth0: MAC: 10, PHY: 11, PBA No: 1011FF-0FF
[    1.245237] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[    1.245241] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[    1.245257] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    1.245277] ehci_hcd 0000:00:1a.0: debug port 2
[    1.249157] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[    1.249171] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7f38000
[    1.260294] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    1.260322] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.260325] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.260328] usb usb1: Product: EHCI Host Controller
[    1.260340] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    1.260341] usb usb1: SerialNumber: 0000:00:1a.0
[    1.260414] hub 1-0:1.0: USB hub found
[    1.260417] hub 1-0:1.0: 3 ports detected
[    1.260479] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[    1.260482] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[    1.260487] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.260505] ehci_hcd 0000:00:1d.0: debug port 2
[    1.264372] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[    1.264384] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7f37000
[    1.276248] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    1.276269] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.276272] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.276275] usb usb2: Product: EHCI Host Controller
[    1.276277] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    1.276280] usb usb2: SerialNumber: 0000:00:1d.0
[    1.276354] hub 2-0:1.0: USB hub found
[    1.276357] hub 2-0:1.0: 3 ports detected
[    1.276406] ahci 0000:00:1f.2: version 3.0
[    1.276474] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
[    1.276476] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[    1.276481] ahci 0000:00:1f.2: setting latency timer to 64
[    1.284561] scsi0 : ahci
[    1.284637] scsi1 : ahci
[    1.284682] scsi2 : ahci
[    1.284727] scsi3 : ahci
[    1.284773] scsi4 : ahci
[    1.284817] scsi5 : ahci
[    1.285092] ata1: SATA max UDMA/133 abar m2048@0xf7f36000 port 0xf7f36100 irq 19
[    1.285095] ata2: SATA max UDMA/133 abar m2048@0xf7f36000 port 0xf7f36180 irq 19
[    1.285096] ata3: DUMMY
[    1.285097] ata4: DUMMY
[    1.285098] ata5: DUMMY
[    1.285099] ata6: DUMMY
[    1.285140] xhci_hcd 0000:00:14.0: setting latency timer to 64
[    1.285144] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.285151] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    1.285245] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.285274] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.285275] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.285277] usb usb3: Product: xHCI Host Controller
[    1.285278] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[    1.285279] usb usb3: SerialNumber: 0000:00:14.0
[    1.285343] xHCI xhci_add_endpoint called for root hub
[    1.285345] xHCI xhci_check_bandwidth called for root hub
[    1.285363] hub 3-0:1.0: USB hub found
[    1.285370] hub 3-0:1.0: 4 ports detected
[    1.285420] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.285423] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    1.285438] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    1.285440] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.285441] usb usb4: Product: xHCI Host Controller
[    1.285442] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[    1.285444] usb usb4: SerialNumber: 0000:00:14.0
[    1.285489] xHCI xhci_add_endpoint called for root hub
[    1.285491] xHCI xhci_check_bandwidth called for root hub
[    1.285506] hub 4-0:1.0: USB hub found
[    1.285512] hub 4-0:1.0: 4 ports detected
[    1.535504] Refined TSC clocksource calibration: 3392.292 MHz.
[    1.535510] Switching to clocksource tsc
[    1.571397] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[    1.603308] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.603330] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.603991] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.603996] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.604000] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.604064] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.604290] ata1.00: ATA-8: SAMSUNG SSD PM830 2.5" 7mm 128GB, CXM03D1Q, max UDMA/133
[    1.604293] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.604722] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.604727] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.604731] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.604797] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.605022] ata1.00: configured for UDMA/133
[    1.607503] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.607507] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.607511] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.607655] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.609512] ata2.00: ATAPI: HL-DT-ST DVD+-RW GT80N, A103, max UDMA/100
[    1.611383] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG SSD PM83 CXM0 PQ: 0 ANSI: 5
[    1.613232] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.613236] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.613240] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.613386] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.615244] ata2.00: configured for UDMA/100
[    1.625042] scsi 1:0:0:0: CD-ROM            HL-DT-ST DVD+-RW GT80N    A103 PQ: 0 ANSI: 5
[    1.627766] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[    1.627838] sd 0:0:0:0: [sda] Write Protect is off
[    1.627841] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.627859] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.628429]  sda: sda1 sda2 < sda5 >
[    1.628642] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.629423] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.629427] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.629518] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    1.630468] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.630493] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    1.703422] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[    1.703427] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.703558] hub 1-1:1.0: USB hub found
[    1.703663] hub 1-1:1.0: 6 ports detected
[    1.814702] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[    1.946721] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[    1.946725] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.946859] hub 2-1:1.0: USB hub found
[    1.946963] hub 2-1:1.0: 8 ports detected
[    2.113845] usb 3-2: new full-speed USB device number 2 using xhci_hcd
[    2.133123] usb 3-2: New USB device found, idVendor=046d, idProduct=c52b
[    2.133127] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.133130] usb 3-2: Product: USB Receiver
[    2.133132] usb 3-2: Manufacturer: Logitech
[    2.135764] usbcore: registered new interface driver usbhid
[    2.135766] usbhid: USB HID core driver
[    2.141029] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
[    2.143870] input: Logitech Unifying Device. Wireless PID:401b as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2/0003:046D:C52B.0003/input/input0
[    2.143918] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:401b] on usb-0000:00:14.0-2:1
[    2.145944] input: Logitech Unifying Device. Wireless PID:4016 as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2/0003:046D:C52B.0003/input/input1
[    2.145971] logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4016] on usb-0000:00:14.0-2:2
[    2.205735] usb 1-1.6: new high-speed USB device number 3 using ehci_hcd
[    2.299213] usb 1-1.6: New USB device found, idVendor=058f, idProduct=6362
[    2.299217] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.299220] usb 1-1.6: Product: Mass Storage Device
[    2.299223] usb 1-1.6: Manufacturer: Generic
[    2.299225] usb 1-1.6: SerialNumber: 058F63626420
[    2.300618] Initializing USB Mass Storage driver...
[    2.300675] scsi6 : usb-storage 1-1.6:1.0
[    2.300715] usbcore: registered new interface driver usb-storage
[    2.300717] USB Mass Storage support registered.
[    3.295260] scsi 6:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0
[    3.295875] scsi 6:0:0:1: Direct-Access     Generic- Compact Flash    1.01 PQ: 0 ANSI: 0
[    3.296373] scsi 6:0:0:2: Direct-Access     Generic- SM/xD Picture    1.02 PQ: 0 ANSI: 0
[    3.296872] scsi 6:0:0:3: Direct-Access     Generic- MS/MS-Pro        1.03 PQ: 0 ANSI: 0
[    3.297205] sd 6:0:0:0: Attached scsi generic sg2 type 0
[    3.297313] sd 6:0:0:1: Attached scsi generic sg3 type 0
[    3.297483] sd 6:0:0:2: Attached scsi generic sg4 type 0
[    3.297565] sd 6:0:0:3: Attached scsi generic sg5 type 0
[    3.300968] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[    3.302844] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[    3.308442] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[    3.309069] sd 6:0:0:3: [sde] Attached SCSI removable disk
[    6.673062] PM: Starting manual resume from disk
[    6.673064] PM: Hibernation image partition 8:5 present
[    6.673065] PM: Looking for hibernation image.
[    6.673298] PM: Image not found (code -22)
[    6.673302] PM: Hibernation image not present or could not be loaded.
[    6.681358] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    6.820057] udevd[425]: starting version 175
[    6.858997] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    6.859003] ACPI: Power Button [PWRB]
[    6.859032] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    6.859034] ACPI: Power Button [PWRF]
[    6.864759] iTCO_vendor_support: vendor-support=0
[    6.865827] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[    6.865886] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[    6.865931] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    6.876468] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    6.883907] [drm] Initialized drm 1.1.0 20060810
[    6.884921] ACPI Warning: 0x0000f000-0x0000f01f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[    6.884926] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    6.894735] [drm] radeon kernel modesetting enabled.
[    6.896871] [drm] initializing kernel modesetting (CAICOS 0x1002:0x6778 0x1028:0x2120).
[    6.896894] [drm] register mmio base: 0xF7E20000
[    6.896896] [drm] register mmio size: 131072
[    6.897138] ATOM BIOS: C26411
[    6.897163] radeon 0000:01:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[    6.897165] radeon 0000:01:00.0: GTT: 512M 0x0000000040000000 - 0x000000005FFFFFFF
[    6.897168] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[    6.897170] [drm] Detected VRAM RAM=1024M, BAR=256M
[    6.897171] [drm] RAM width 64bits DDR
[    6.897273] [TTM] Zone  kernel: Available graphics memory: 433244 kiB
[    6.897275] [TTM] Zone highmem: Available graphics memory: 1806866 kiB
[    6.897276] [TTM] Initializing pool allocator
[    6.897289] [drm] radeon: 1024M of VRAM memory ready
[    6.897290] [drm] radeon: 512M of GTT memory ready.
[    6.897298] [drm] GART: num cpu pages 131072, num gpu pages 131072
[    6.897755] [drm] radeon: ib pool ready.
[    6.897806] [drm] Loading CAICOS Microcode
[    6.900763] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    6.925709] hda_codec: ALC269VB: SKU not ready 0x411111f0
[    6.928150] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input4
[    6.931853] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[    6.931889] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[    6.931921] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[    6.931956] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    7.811911] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000).
[    7.812021] radeon 0000:01:00.0: WB enabled
[    7.812024] [drm] fence driver on ring 0 use gpu addr 0x40000c00 and cpu addr 0xff9d7c00
[    7.812026] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    7.812027] [drm] Driver supports precise vblank timestamp query.
[    7.812057] [drm] radeon: irq initialized.
[    7.828251] [drm] ring test on 0 succeeded in 3 usecs
[    7.828387] [drm] ib test on ring 0 succeeded in 0 usecs
[    7.828778] [drm] Radeon Display Connectors
[    7.828779] [drm] Connector 0:
[    7.828780] [drm]   DisplayPort
[    7.828781] [drm]   HPD2
[    7.828783] [drm]   DDC: 0x6460 0x6460 0x6464 0x6464 0x6468 0x6468 0x646c 0x646c
[    7.828784] [drm]   Encoders:
[    7.828785] [drm]     DFP1: INTERNAL_UNIPHY1
[    7.828786] [drm] Connector 1:
[    7.828787] [drm]   DVI-I
[    7.828788] [drm]   HPD4
[    7.828789] [drm]   DDC: 0x6450 0x6450 0x6454 0x6454 0x6458 0x6458 0x645c 0x645c
[    7.828790] [drm]   Encoders:
[    7.828791] [drm]     DFP2: INTERNAL_UNIPHY
[    7.828792] [drm]     CRT1: INTERNAL_KLDSCP_DAC1
[    7.828855] [drm] Internal thermal controller without fan control
[    7.829682] [drm] radeon: power management initialized
[    7.899875] [drm] fb mappable at 0xE0142000
[    7.899876] [drm] vram apper at 0xE0000000
[    7.899877] [drm] size 8294400
[    7.899878] [drm] fb depth is 24
[    7.899879] [drm]    pitch is 7680
[    7.899914] fbcon: radeondrmfb (fb0) is primary device
[    8.309479] Console: switching to colour frame buffer device 240x67
[    8.312794] fb0: radeondrmfb frame buffer device
[    8.312796] drm: registered panic notifier
[    8.312799] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[    8.329988] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[    8.487957] Adding 5105660k swap on /dev/sda5.  Priority:-1 extents:1 across:5105660k SS
[    8.495197] EXT4-fs (sda1): re-mounted. Opts: (null)
[    8.531141] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    8.543223] loop: module loaded
[    8.853372] RPC: Registered named UNIX socket transport module.
[    8.853374] RPC: Registered udp transport module.
[    8.853375] RPC: Registered tcp transport module.
[    8.853376] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    8.856907] FS-Cache: Loaded
[    8.860932] NFS: Registering the id_resolver key type
[    8.860942] FS-Cache: Netfs 'nfs' registered for caching
[    8.863898] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    9.197698] Bluetooth: Core ver 2.16
[    9.197709] NET: Registered protocol family 31
[    9.197710] Bluetooth: HCI device and connection manager initialized
[    9.197712] Bluetooth: HCI socket layer initialized
[    9.197713] Bluetooth: L2CAP socket layer initialized
[    9.197716] Bluetooth: SCO socket layer initialized
[    9.199801] Bluetooth: RFCOMM TTY layer initialized
[    9.199804] Bluetooth: RFCOMM socket layer initialized
[    9.199806] Bluetooth: RFCOMM ver 1.11
[    9.202063] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.202065] Bluetooth: BNEP filters: protocol multicast
[    9.211174] lp: driver loaded but no devices found
[    9.213719] ppdev: user-space parallel port driver
[    9.427862] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.094440] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input10
[   11.051142] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx
[   11.051146] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[   11.051224] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  228.435866] I-pipe: head domain RTAI registered.
[  228.435869] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  228.435912] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  228.435914] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[  228.435916] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  228.435918] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6182500
[  228.444326] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  228.444342] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  228.444345] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[  228.444347] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[  228.444348] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  228.451040] RTAI[math]: loaded.
[  228.638201] RTAI[math]: unloaded.
[  228.639059] SCHED releases registered named ALIEN PEDV$D
[  228.641122] RTAI[malloc]: unloaded.
[  228.737759] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  228.738666] I-pipe: head domain RTAI unregistered.
[  228.738713] RTAI[hal]: unmounted.
[  806.941841] I-pipe: head domain RTAI registered.
[  806.941844] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  806.941887] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  806.941889] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[  806.941890] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  806.941892] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5235000
[  806.945027] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  806.945043] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  806.945046] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[  806.945048] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[  806.945049] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  806.949433] RTAI[math]: loaded.
[  807.124388] RTAI[math]: unloaded.
[  807.125238] SCHED releases registered named ALIEN PEDV$D
[  807.127395] RTAI[malloc]: unloaded.
[  807.223444] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  807.224364] I-pipe: head domain RTAI unregistered.
[  807.224410] RTAI[hal]: unmounted.
any help or thoughts would be very appreciated.
5 years 3 months ago #215439 by Aciera
The important part seems to be this line:
So it looks like you have a line somewhere in your ini or hal that tells the system to call up a file named "BigGrayBeast.hal" and that file does not seem to exist in your config folder.
5 years 3 months ago #215443 by tommylight
FYI, everything in Linux is case sensitive.
5 years 3 months ago #215498 by mjones@welfab.ca
i did see and correct that problem yeasterday then tried again and it said there was a problem with classicladder. So I made a new basix pnc.config. to see if i can get that going. it seems that i have a problem connecting proper to the boards. not sure what ones. seem that the 7i77 connects but 7i76e and 7i64 arent connecting.
here is the error message, wish it would let me copy just the debug info. my hal for the connections must be wrong, but im not sure where
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.15
Machine configuration directory is '/home/hard/linuxcnc/configs/test4'
Machine configuration file is 'test4.ini'
INIFILE=/home/hard/linuxcnc/configs/test4/test4.ini
TASK=milltask
HALUI=halui
DISPLAY=axis
Found file(REL): ./test4.hal
Running HAL shutdown script
./test4.hal:27: Pin 'hm2_5i25.0.7i77.0.0.input-00' does not exist
9739
[ 0.196479] #2
[ 0.216420] #3 Ok.
[ 0.232434] dummy:
[ 3869.984646] I-pipe: head domain RTAI registered.
[ 3869.984650] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3869.984707] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3869.984710] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 3869.984711] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3869.984713] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 4162500
[ 3869.987905] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3869.987922] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3869.987925] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 3869.987927] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 3869.987928] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3869.992714] RTAI[math]: loaded.
[ 3870.003694] config string '0 out'
[ 3870.004270] PARPORT: ERROR: linux parport 0 not found
[ 3879.723387] RTAI[math]: unloaded.
[ 3879.724241] SCHED releases registered named ALIEN PEDV$D
[ 3879.726903] RTAI[malloc]: unloaded.
[ 3879.824639] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3879.825574] I-pipe: head domain RTAI unregistered.
[ 3879.825621] RTAI[hal]: unmounted.
[ 3943.053667] I-pipe: head domain RTAI registered.
[ 3943.053671] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3943.053713] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3943.053715] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 3943.053716] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3943.053718] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5838250
[ 3943.056849] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3943.056866] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3943.056868] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 3943.056870] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 3943.056871] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3943.061768] RTAI[math]: loaded.
[ 3943.109315] hm2: loading Mesa HostMot2 driver version 0.15
[ 3943.111508] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3943.111534] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 3943.112128] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3943.116048] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 3943.118719] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 3943.203350] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3943.203352] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 3943.203354] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 3943.203356] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 3943.203357] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 3943.203359] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 3943.203361] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3943.203362] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3943.203364] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3943.203365] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3943.203367] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3943.203369] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3943.203370] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 3943.203372] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 3943.203374] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 3943.203375] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 3943.203377] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 3943.203378] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 3943.203380] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3943.203381] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3943.203382] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3943.203384] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3943.203385] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3943.203386] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3943.203387] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3943.203389] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3943.203390] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3943.203391] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3943.203392] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3943.203394] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3943.203395] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3943.203396] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3943.203397] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3943.203398] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3943.203400] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3943.203444] hm2/hm2_5i25.0: registered
[ 3943.203446] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 3943.330256] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 3943.330260] hm2/hm2_5i25.0: unregistered
[ 3943.330296] hm2_pci: driver unloaded
[ 3943.331167] hm2: unloading
[ 3945.371515] RTAI[math]: unloaded.
[ 3945.372367] SCHED releases registered named ALIEN PEDV$D
[ 3945.374610] RTAI[malloc]: unloaded.
[ 3945.472897] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3945.473792] I-pipe: head domain RTAI unregistered.
[ 3945.473838] RTAI[hal]: unmounted.
[ 4753.983872] I-pipe: head domain RTAI registered.
[ 4753.983876] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4753.983918] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4753.983920] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 4753.983921] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4753.983923] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5400750
[ 4753.987035] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4753.987051] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4753.987054] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 4753.987056] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 4753.987057] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4753.992588] RTAI[math]: loaded.
[ 4754.030973] hm2: loading Mesa HostMot2 driver version 0.15
[ 4754.031964] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4754.031990] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 4754.032852] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4754.036730] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 4754.039399] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 4754.124254] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4754.124256] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 4754.124258] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 4754.124260] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 4754.124262] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 4754.124263] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 4754.124265] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 4754.124266] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 4754.124268] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4754.124270] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4754.124271] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4754.124273] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4754.124275] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4754.124276] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4754.124278] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4754.124280] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4754.124281] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4754.124283] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4754.124284] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4754.124286] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4754.124287] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4754.124288] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4754.124289] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4754.124290] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4754.124292] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4754.124293] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 4754.124294] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 4754.124295] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 4754.124297] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 4754.124298] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 4754.124299] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 4754.124300] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 4754.124302] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 4754.124303] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 4754.124304] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 4754.124353] hm2/hm2_5i25.0: registered
[ 4754.124355] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 4754.131682] classicladder_rt: module license 'LGPL' taints kernel.
[ 4754.131684] Disabling lock debugging due to kernel taint
[ 4754.131796] creating ladder-state
[ 4754.310857] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 4754.310861] hm2/hm2_5i25.0: unregistered
[ 4754.310890] hm2_pci: driver unloaded
[ 4754.311772] hm2: unloading
[ 4756.355733] RTAI[math]: unloaded.
[ 4756.356584] SCHED releases registered named ALIEN PEDV$D
[ 4756.358850] RTAI[malloc]: unloaded.
[ 4756.457708] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4756.458614] I-pipe: head domain RTAI unregistered.
[ 4756.458662] RTAI[hal]: unmounted.
[ 4851.765208] I-pipe: head domain RTAI registered.
[ 4851.765212] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4851.765254] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4851.765256] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 4851.765257] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4851.765259] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6230000
[ 4851.768359] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4851.768376] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4851.768378] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 4851.768380] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 4851.768382] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4851.772778] RTAI[math]: loaded.
[ 4851.950806] RTAI[math]: unloaded.
[ 4851.951656] SCHED releases registered named ALIEN PEDV$D
[ 4851.953814] RTAI[malloc]: unloaded.
[ 4852.052325] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4852.053237] I-pipe: head domain RTAI unregistered.
[ 4852.053284] RTAI[hal]: unmounted.
[ 5207.872767] I-pipe: head domain RTAI registered.
[ 5207.872770] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 5207.872812] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5207.872814] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 5207.872816] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5207.872818] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6192750
[ 5207.875955] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5207.875971] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5207.875974] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 5207.875976] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 5207.875977] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 5207.880429] RTAI[math]: loaded.
[ 5207.918886] hm2: loading Mesa HostMot2 driver version 0.15
[ 5207.919910] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 5207.919936] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 5207.920795] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 5207.924674] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 5207.927344] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 5208.012402] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 5208.012405] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 5208.012407] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 5208.012408] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 5208.012410] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 5208.012412] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 5208.012413] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 5208.012415] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 5208.012416] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 5208.012418] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 5208.012420] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 5208.012421] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 5208.012423] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 5208.012425] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 5208.012426] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 5208.012428] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 5208.012429] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 5208.012431] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 5208.012433] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 5208.012434] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 5208.012435] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 5208.012436] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 5208.012438] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 5208.012439] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 5208.012440] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 5208.012441] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 5208.012442] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 5208.012444] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 5208.012445] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 5208.012446] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 5208.012447] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 5208.012449] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 5208.012450] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 5208.012451] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 5208.012452] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 5208.012502] hm2/hm2_5i25.0: registered
[ 5208.012503] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 5208.016105] creating ladder-state
[ 5208.177550] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 5208.177554] hm2/hm2_5i25.0: unregistered
[ 5208.177593] hm2_pci: driver unloaded
[ 5208.178670] hm2: unloading
[ 5210.222708] RTAI[math]: unloaded.
[ 5210.223562] SCHED releases registered named ALIEN PEDV$D
[ 5210.225737] RTAI[malloc]: unloaded.
[ 5210.323768] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5210.324748] I-pipe: head domain RTAI unregistered.
[ 5210.324796] RTAI[hal]: unmounted.
[ 6487.291469] I-pipe: head domain RTAI registered.
[ 6487.291473] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 6487.291517] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6487.291519] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[ 6487.291520] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6487.291522] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6187250
[ 6487.294648] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6487.294667] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6487.294669] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 6487.294671] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[ 6487.294672] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 6487.299603] RTAI[math]: loaded.
[ 6487.338199] hm2: loading Mesa HostMot2 driver version 0.15
[ 6487.339196] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 6487.339224] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 6487.340087] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 6487.343963] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 6487.346632] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 6487.431499] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 6487.431501] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[ 6487.431502] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[ 6487.431504] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[ 6487.431506] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 6487.431508] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 6487.431509] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 6487.431511] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 6487.431512] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 6487.431514] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 6487.431516] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 6487.431517] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 6487.431519] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 6487.431521] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 6487.431522] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 6487.431524] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 6487.431525] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 6487.431527] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 6487.431529] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 6487.431530] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 6487.431531] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 6487.431532] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 6487.431534] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 6487.431535] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 6487.431536] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 6487.431537] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 6487.431538] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 6487.431540] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 6487.431541] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 6487.431542] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 6487.431543] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 6487.431545] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 6487.431546] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 6487.431547] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 6487.431548] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 6487.431598] hm2/hm2_5i25.0: registered
[ 6487.431599] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 6487.435134] creating ladder-state
[ 6487.623683] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 6487.623686] hm2/hm2_5i25.0: unregistered
[ 6487.623750] hm2_pci: driver unloaded
[ 6487.624846] hm2: unloading
[ 6489.669008] RTAI[math]: unloaded.
[ 6489.669863] SCHED releases registered named ALIEN PEDV$D
[ 6489.671981] RTAI[malloc]: unloaded.
[ 6489.768899] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6489.769808] I-pipe: head domain RTAI unregistered.
[ 6489.769855] RTAI[hal]: unmounted.
[71852.945619] I-pipe: head domain RTAI registered.
[71852.945623] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[71852.945665] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[71852.945667] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[71852.945668] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[71852.945670] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6228750
[71852.948778] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[71852.948794] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[71852.948796] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[71852.948798] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[71852.948799] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[71852.953256] RTAI[math]: loaded.
[71852.991143] hm2: loading Mesa HostMot2 driver version 0.15
[71852.992092] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[71852.992119] hm2_pci: discovered 5i25 at 0000:04:00.0
[71852.992691] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[71852.996610] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[71852.999281] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[71853.083952] hm2/hm2_5i25.0: 34 I/O Pins used:
[71853.083954] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[71853.083956] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[71853.083958] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[71853.083960] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[71853.083961] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[71853.083963] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[71853.083964] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[71853.083966] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[71853.083967] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[71853.083969] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[71853.083971] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[71853.083972] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[71853.083974] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[71853.083976] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[71853.083977] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[71853.083978] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[71853.083980] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[71853.083981] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[71853.083982] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[71853.083983] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[71853.083984] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[71853.083986] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[71853.083987] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[71853.083988] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[71853.083989] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[71853.083991] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[71853.083992] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[71853.083993] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[71853.083994] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[71853.083999] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[71853.084001] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[71853.084003] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[71853.084005] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[71853.084006] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[71853.084048] hm2/hm2_5i25.0: registered
[71853.084050] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[71853.221444] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[71853.221448] hm2/hm2_5i25.0: unregistered
[71853.221476] hm2_pci: driver unloaded
[71853.222349] hm2: unloading
[71855.267451] RTAI[math]: unloaded.
[71855.268319] SCHED releases registered named ALIEN PEDV$D
[71855.270540] RTAI[malloc]: unloaded.
[71855.368913] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[71855.369819] I-pipe: head domain RTAI unregistered.
[71855.369866] RTAI[hal]: unmounted.
[72364.521772] I-pipe: head domain RTAI registered.
[72364.521776] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72364.521818] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72364.521820] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[72364.521821] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72364.521823] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6229250
[72364.524953] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72364.524970] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72364.524973] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[72364.524975] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[72364.524976] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72364.529059] RTAI[math]: loaded.
[72364.567148] hm2: loading Mesa HostMot2 driver version 0.15
[72364.568093] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[72364.568120] hm2_pci: discovered 5i25 at 0000:04:00.0
[72364.568707] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[72364.572626] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[72364.575294] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[72364.659961] hm2/hm2_5i25.0: 34 I/O Pins used:
[72364.659963] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[72364.659965] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[72364.659967] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[72364.659968] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[72364.659970] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[72364.659972] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[72364.659973] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[72364.659975] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[72364.659976] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[72364.659978] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[72364.659980] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[72364.659981] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[72364.659983] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[72364.659985] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[72364.659987] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[72364.659989] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[72364.659990] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[72364.659992] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[72364.659993] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[72364.659994] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[72364.659996] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[72364.659997] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[72364.659998] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[72364.659999] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[72364.660001] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[72364.660002] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[72364.660003] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[72364.660004] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[72364.660005] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[72364.660007] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[72364.660008] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[72364.660009] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[72364.660010] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[72364.660012] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[72364.660052] hm2/hm2_5i25.0: registered
[72364.660054] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[72364.662279] creating ladder-state
[72364.792504] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[72364.792507] hm2/hm2_5i25.0: unregistered
[72364.792535] hm2_pci: driver unloaded
[72364.793366] hm2: unloading
[72366.838295] RTAI[math]: unloaded.
[72366.839149] SCHED releases registered named ALIEN PEDV$D
[72366.841437] RTAI[malloc]: unloaded.
[72366.937967] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72366.938917] I-pipe: head domain RTAI unregistered.
[72366.938963] RTAI[hal]: unmounted.
[72461.339397] I-pipe: head domain RTAI registered.
[72461.339401] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72461.339444] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72461.339446] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[72461.339447] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72461.339449] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6194250
[72461.342567] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72461.342583] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72461.342585] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[72461.342587] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[72461.342589] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72461.347017] RTAI[math]: loaded.
[72461.385888] hm2: loading Mesa HostMot2 driver version 0.15
[72461.386892] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[72461.386920] hm2_pci: discovered 5i25 at 0000:04:00.0
[72461.387785] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[72461.391658] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[72461.394327] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[72461.479213] hm2/hm2_5i25.0: 34 I/O Pins used:
[72461.479216] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[72461.479217] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[72461.479219] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[72461.479221] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[72461.479223] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[72461.479224] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[72461.479226] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[72461.479227] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[72461.479229] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[72461.479231] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[72461.479232] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[72461.479234] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[72461.479236] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[72461.479237] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[72461.479239] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[72461.479241] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[72461.479242] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[72461.479244] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[72461.479245] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[72461.479246] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[72461.479247] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[72461.479249] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[72461.479250] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[72461.479251] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[72461.479252] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[72461.479254] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[72461.479255] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[72461.479256] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[72461.479257] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[72461.479258] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[72461.479260] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[72461.479261] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[72461.479262] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[72461.479263] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[72461.479313] hm2/hm2_5i25.0: registered
[72461.479314] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[72461.482897] creating ladder-state
[72461.650091] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[72461.650095] hm2/hm2_5i25.0: unregistered
[72461.650124] hm2_pci: driver unloaded
[72461.651005] hm2: unloading
[72463.694523] RTAI[math]: unloaded.
[72463.695375] SCHED releases registered named ALIEN PEDV$D
[72463.697401] RTAI[malloc]: unloaded.
[72463.796971] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72463.797885] I-pipe: head domain RTAI unregistered.
[72463.797932] RTAI[hal]: unmounted.
[72537.926415] I-pipe: head domain RTAI registered.
[72537.926419] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72537.926461] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72537.926463] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[72537.926464] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72537.926466] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5435500
[72537.929620] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72537.929636] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72537.929639] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[72537.929641] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[72537.929642] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72537.933903] RTAI[math]: loaded.
[72537.972639] hm2: loading Mesa HostMot2 driver version 0.15
[72537.973648] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[72537.973675] hm2_pci: discovered 5i25 at 0000:04:00.0
[72537.974538] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[72537.978414] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[72537.981086] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[72538.065976] hm2/hm2_5i25.0: 34 I/O Pins used:
[72538.065978] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[72538.065980] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[72538.065982] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[72538.065983] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[72538.065985] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[72538.065987] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[72538.065988] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[72538.065990] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[72538.065991] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[72538.065993] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[72538.065995] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[72538.065996] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[72538.065998] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[72538.066000] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[72538.066001] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[72538.066003] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[72538.066004] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[72538.066006] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[72538.066007] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[72538.066008] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[72538.066010] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[72538.066011] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[72538.066012] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[72538.066013] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[72538.066014] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[72538.066016] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[72538.066017] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[72538.066018] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[72538.066019] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[72538.066020] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[72538.066022] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[72538.066023] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[72538.066024] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[72538.066025] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[72538.066075] hm2/hm2_5i25.0: registered
[72538.066076] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[72538.069636] creating ladder-state
[72538.261786] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[72538.261790] hm2/hm2_5i25.0: unregistered
[72538.261830] hm2_pci: driver unloaded
[72538.262766] hm2: unloading
[72540.306256] RTAI[math]: unloaded.
[72540.307112] SCHED releases registered named ALIEN PEDV$D
[72540.309066] RTAI[malloc]: unloaded.
[72540.405902] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72540.406797] I-pipe: head domain RTAI unregistered.
[72540.406843] RTAI[hal]: unmounted.
[73212.931803] I-pipe: head domain RTAI registered.
[73212.931807] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[73212.931849] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[73212.931851] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[73212.931853] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[73212.931855] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5872750
[73212.934981] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[73212.934997] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[73212.935000] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[73212.935002] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[73212.935003] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[73212.938853] RTAI[math]: loaded.
[73212.976876] hm2: loading Mesa HostMot2 driver version 0.15
[73212.977826] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[73212.977852] hm2_pci: discovered 5i25 at 0000:04:00.0
[73212.978498] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[73212.982419] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[73212.985087] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[73213.069745] hm2/hm2_5i25.0: 34 I/O Pins used:
[73213.069748] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[73213.069750] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[73213.069752] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[73213.069754] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[73213.069755] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[73213.069757] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[73213.069758] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[73213.069760] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[73213.069761] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[73213.069763] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[73213.069765] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[73213.069766] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[73213.069768] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[73213.069770] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[73213.069771] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[73213.069773] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[73213.069774] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[73213.069776] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[73213.069777] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[73213.069778] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[73213.069780] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[73213.069781] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[73213.069782] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[73213.069783] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[73213.069785] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[73213.069786] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[73213.069787] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[73213.069788] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[73213.069789] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[73213.069791] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[73213.069792] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[73213.069793] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[73213.069794] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[73213.069796] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[73213.069838] hm2/hm2_5i25.0: registered
[73213.069840] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[73213.199287] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[73213.199290] hm2/hm2_5i25.0: unregistered
[73213.199320] hm2_pci: driver unloaded
[73213.200151] hm2: unloading
[73215.241794] RTAI[math]: unloaded.
[73215.242664] SCHED releases registered named ALIEN PEDV$D
[73215.244686] RTAI[malloc]: unloaded.
[73215.343753] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[73215.344665] I-pipe: head domain RTAI unregistered.
[73215.344711] RTAI[hal]: unmounted.
[74069.654705] I-pipe: head domain RTAI registered.
[74069.654709] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[74069.654751] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[74069.654753] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3392191000, CPU_FREQ 3392191000
[74069.654755] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[74069.654757] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5948500
[74069.657897] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[74069.657913] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[74069.657915] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[74069.657917] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392191000 hz.
[74069.657919] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[74069.667361] RTAI[math]: loaded.
[74069.705261] hm2: loading Mesa HostMot2 driver version 0.15
[74069.706219] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[74069.706246] hm2_pci: discovered 5i25 at 0000:04:00.0
[74069.706892] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[74069.710760] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[74069.713435] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[74069.798135] hm2/hm2_5i25.0: 34 I/O Pins used:
[74069.798137] hm2/hm2_5i25.0: IO Pin 000 (P3-01): Smart Serial Interface #0, pin TxEn2 (Output)
[74069.798138] hm2/hm2_5i25.0: IO Pin 001 (P3-14): Smart Serial Interface #0, pin TxData2 (Output)
[74069.798140] hm2/hm2_5i25.0: IO Pin 002 (P3-02): Smart Serial Interface #0, pin RxData2 (Input)
[74069.798142] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[74069.798144] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[74069.798145] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[74069.798147] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[74069.798148] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[74069.798150] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[74069.798152] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[74069.798153] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[74069.798155] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[74069.798157] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[74069.798158] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[74069.798160] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[74069.798162] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[74069.798163] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[74069.798165] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[74069.798166] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[74069.798167] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[74069.798168] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[74069.798170] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[74069.798171] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[74069.798172] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[74069.798173] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[74069.798175] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[74069.798176] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[74069.798177] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[74069.798178] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[74069.798180] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[74069.798181] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[74069.798182] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[74069.798183] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[74069.798184] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[74069.798227] hm2/hm2_5i25.0: registered
[74069.798228] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[74069.927277] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[74069.927281] hm2/hm2_5i25.0: unregistered
[74069.927310] hm2_pci: driver unloaded
[74069.928144] hm2: unloading
[74071.969253] RTAI[math]: unloaded.
[74071.970108] SCHED releases registered named ALIEN PEDV$D
[74071.972494] RTAI[malloc]: unloaded.
[74072.069748] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[74072.070652] I-pipe: head domain RTAI unregistered.
[74072.070700] RTAI[hal]: unmounted.
5 years 3 months ago #215499 by andypugh
This means that the field-power to the 7i76 is not connected. The smart-serial part of the 7i76 is powered by the field power, so without field power the 7i76 GPIO won't show up.
5 years 3 months ago - 5 years 3 months ago #215500 by PCW
[ 4754.124265] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort   <<<<<<<<<<<<<<< Missing TX0
[ 4754.124266] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort  <<<<<<<<<<<<<<<  Missing RX0
 and
Indicate that LinuxCNC did not find the 7I77s digital I/O section. (but did find the analog section and something
plugged into the 7I77s sserial expansion connector).  Do you have field power on the 7I77s orange connector?
Last edit: 5 years 3 months ago by PCW.
Time to create page: 0.618 seconds
