new pnc.config won't load in linuxcnc
5 years 3 months ago #215611 by PCW
If it was ordered from Mesa and not shipped yet, we can cancel the order if you wish
5 years 3 months ago #215791 by mjones@welfab.ca
Ok. I wasn't able to do anything with this yesterday, had to work on site. I now have connected the 7i76e through eithernet and can ping it. but now i have no idea how to do a pnc.config as it doesnt give an eithernet option, only pci and parallel options. I am still running the 7i77 and 7i64 through the 6i25 but trying to run the 7i76e through eithernet. is this wrong should i connect the 7i77 and 7i64 to the 7i76e and run it all on eithernet? either way i need to know how to make a hal file to connect to the 7i76e,
5 years 3 months ago #215796 by PCW
Pncconf can setup a Ethernet connected 7I76E but I don't think it can setup a 7I77
daughters card attached to a 7I76E.
You could use a 5i25 /7i76/7i77 configuration and edit the hal file to change the driver
command line from hm2_pci to hm2_eth, add the ip address in the driver
command line, and change the card name from 5i25 to 7i76e in the ini file
5 years 3 months ago #215797 by mjones@welfab.ca
would i have to reflash the 6i25 for the 5i25-7i76/7i77 configuration?
5 years 3 months ago #215798 by PCW
You would have to reflash the 7I76E with firmware that supports a 7I77
5 years 3 months ago #215858 by mjones@welfab.ca
im having a proplem getting the
cd to ~/configs/hostmot2/
command to work, i remember having a problem last time but i ran through all the files it had to go to to get there and got it to work but can't get it to work now.
