Re:pncconf - feature requests
- calvin.d
10 years 1 month ago #79952
by calvin.d
Replied by calvin.d on topic pncconf - feature requests
request for allowing usb devices to be configured for gs2-vfd setup
they are going to be dev/ttyUSB# where # starts at 0
also in the gs2-vfd config that is generated
the line
net spindle-on => spindle-vfd.spindle-on
need to be changed to
net spindle-enable => spindle-vfd.spindle-on
for it to work for me
Thank You
Calvin
the line
Thank You
Calvin
- Thank you received: 2181
10 years 1 month ago #79956
Replied by cmorley on topic pncconf - feature requests
ok I pushed a change for the ability to set the device name for the gs2 vfd.
And fixed the signal name spindle-on
next release of 2.7 series should have it.
Chris M
Chris M
- calvin.d
10 years 1 month ago #80102
by calvin.d
ok found 2 more issues
7i76 encoder mode 2 is not being set properly in the hal file
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
should be
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=20xxxx"
and I had an interesting error
net joint-selected-count <= hm2_5i25.0.7i76.0.0.enc0.count
should be
net joint-selected-count <= hm2_5i25.encoder.00.count
i have attached the config it generated
Thank You
Calvin
should be
should be
Thank You
Calvin
- Thank you received: 5334
10 years 1 month ago - 10 years 1 month ago #80104
I dont think that's an error
(the 5i25 encoder is used for the spindle while the 7i76 MPG encoder is used for jogging)
Replied by PCW on topic pncconf - feature requests
should be
Last edit: 10 years 1 month ago by PCW.
- calvin.d
10 years 1 month ago #80106
by calvin.d
i see, so it is still wrong, just not in the way I thought it was
let me change it to your way and see what happens
C
C
- calvin.d
10 years 1 month ago #80107
by calvin.d
ok still not quite right
this works
net joint-selected-count <= hm2_5i25.0.encoder.00.count
my mpg is still not working but it at least loads nows
also is the mode 2 change issue a known problem ?
C
this works
C
Time to create page: 0.162 seconds
