- Thank you received: 2181
Re:pncconf - feature requests
4 years 8 months ago #234194
Replied by cmorley on topic Re:pncconf - feature requests
So you didn't look at the code... it's python by the way.
The numbering system is 'calculated' from the firmware declarations.
While sometimes you can easily convert that to actual pins numbers,
as Peter said if the daughter board is 1:1 pin mapping, in some cases you don't have enough information to do so.
i don't think having the pins numbers sometimes be actual physical numbering and sometimes be component numbering is helpful.
If you limit the configurable boards to a subset it becomes easier or if you program every daughterboard firmware available into pncconf you could do this or if the daughterboards pin conversions could be read from mesaflash that would be pretty easy.
- smc.collins
- Thank you received: 139
4 years 8 months ago #234545
by smc.collins
Replied by smc.collins on topic Re:pncconf - feature requests
I've actually been busy working, and in my spare time learning my way around the code base. GTK and Python are new things for me to learn. There seems to be a lot of abstraction in the code base as well.
Calculating pins, why ?? each card has a fixed hardware design, IE a screen mask which declares the relative position on the hardware of where a IO location is.
A simple text file like a INI for each card would have removed a massive user facing error inducing design choice.
- Thank you received: 4153
4 years 8 months ago #234600
Replied by rodw on topic Re:pncconf - feature requests
Its not simple and the mesa environment does not work that way. I might have a 7i76e plugged in and then I might plug in two more cards. Lets say 2 x 7i76 so now we have 15 stepgens and a heap more IO pins. So lets now add a Mesa 7i73 smart serial device that will add another 40 odd pins. Somehow poor old pncconf has to manage all of that complexity..
Computers count starting from 0 (what is the first index into a C based array?), hardware pin numbers start at 1. There are very good reasons why computers start counting at 0. Its much more efficient at the hardware level. The whole of linuxcnc starts numbering from 0. Why should Mesa be treated any different?
Life will be much simpler if you just accept the paradigm and get a working machine. It does not matter what system in the universe you use, it has an accepted paradigm and if you try to fight the paradigm, life is very unpleasant. That applies to linuxcnc. Remember, linuxcnc is free software and there are no paid developers on standby. Embrace the paradigm and get on with life!
4 years 8 months ago #234613
If you are talking about cards that are fairly hardware unconfiguarable such as 7i76e or most daughter cards, then a hard coded lookup table or INI style file would work fine.
Pncconf covers cards such as the 5i20 (not so popular now) that are completely hardware configurable with custom firmware or the standard firmware by 'turning off' modules such as step components to reveal GPIO.
and probably more importantly Pncconf was built when these were the only cards so all the data paradigms and basic programming were laid out.
Also this is the program I used to learn python. (so ya the programming code is not very nice)
I want to say that - I am not against changes to make this happen, it's just I don't see how to get all the way there without some help on the hardware side and any way to get there will require significant work.
I am certainly not the best coder and would be happy to either remove pncconf for a better program or let someone else to take it over. I am mostly just doing work to keep it running and incorporating code others have offered (there have been many) and bug fixing.
Thank you for your questions and suggestions
Chris
Chris
- Thank you received: 5334
4 years 8 months ago - 4 years 8 months ago #234619
Replied by PCW on topic Re:pncconf - feature requests
Also even on relatively fixed cards like the 7I76E, step/dir pins can
be used for PWM or other functions so a fixed table is pretty limiting,
and this is ignoring 7I76E daughterboards.
The discovery option with mesaflash's pinout list would cover most bases,
especially if mesaflash's daughterboard hints are used.
Last edit: 4 years 8 months ago by PCW. Reason: Fix formatting
- Tokik
2 years 7 months ago #296531
by Tokik
Replied by Tokik on topic pncconf - feature requests
Good afternoon Is it possible to add an MB control board (controller) to the PnCConf Wizard, is it an analogue of the MESA 7I92 board combined with a switching board? Manufacturer’s website
www.smd-taxi.ru/mesa-linuxcnc
Time to create page: 0.143 seconds
