- Thank you received: 2181
Re:pncconf - feature requests
6 years 1 month ago #181088
IIRC, I didn't draw it I colored it and changed some labels.
I might of taken a different card's image and edited it.
I use GIMP, which is not friendly if you only use it once in a while.
Chris
Replied by cmorley on topic pncconf - feature requests
JohnnyCNC wrote: Chris,
What app are you using to draw that board? I need to document the wiring of my machine and I don't have a tool that makes it easy to draw a simple diagram.
Chris
- JohnnyCNC
- Thank you received: 115
6 years 1 month ago #181155
by JohnnyCNC
Replied by JohnnyCNC on topic pncconf - feature requests
Thanks, I've used Eagle CAD but that is way to complicated for doing a simple wiring diagram and MS Paint is way too primitive. I guess I have some Googling to do.
- shadab
- Thank you received: 4
6 years 1 month ago #181381
by shadab
Hi Chris,
We are working with 7i97 to retrofit a HURCO Hawk 30 as discussed in this forum post and might be able to help you get the data you need. Let us know what data you need and we will send it to you.
Shadab
Replied by shadab on topic pncconf - feature requests
cmorley wrote:
shadab wrote: Hi,
Is there any news on when 7i97 will be supported for the 7i97?
It's not on my radar currently, but if someone could post the output from mesaflash for it's pins and sserial that might motivate me.
Chris
Hi Chris,
Shadab
6 years 1 month ago #181385
looking for the output from these commands (address might be different for yours)
mesaflash --device 7i97 --addr 192.168.1.121
mesaflash --device 7i97 --addr 192.168.1.121 --sserial
mesaflash --device 7i97 --addr 192.168.1.121 --readhmid
- shadab
5 years 11 months ago - 5 years 11 months ago #190105
by shadab
Hi Chris,
The reponses from mesaflash for the following commands:
mesaflash --device 7i97 --addr 10.10.10.10
ETH device 7I97 at ip=10.10.10.10
mesaflash --device 7i97 --addr 10.10.10.10 --sserial
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 1
SSLBP Baud Rate: 2500000
I have attached the output of -readhmid command below:
Thanks,
Shadab
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 1
Thanks,
Shadab
Last edit: 5 years 11 months ago by shadab. Reason: Formatting didn't come out correctly for --readhmid comand, adding a text file with that output.
- smc.collins
- Thank you received: 139
4 years 8 months ago - 4 years 8 months ago #234062
by smc.collins
Replied by smc.collins on topic Re:pncconf - feature requests
Renumber PNC conf inputs and outputs to match screen masking on the cards the drivers support. this off by one thing is kind weird, it also create a room for more errors. The screen masking of the Board should match the numbering of the driver IO etc. Remember, NASA lost a mars mission of a converison error.
Last edit: 4 years 8 months ago by smc.collins.
Time to create page: 0.161 seconds
