New install of Mesa 7i92 on TCL lathe
- john11668
- Thank you received: 10
22 Apr 2022 09:05 - 22 Apr 2022 09:06 #240866
by john11668
Replied by john11668 on topic New install of Mesa 7i92 on TCL lathe
I do have a spare pci slot currently occupied by a parallel port card which will hopefully become redundant . What do I need to put in there .
What is the instruction to identify the version of mint I am using.
Last edit: 22 Apr 2022 09:06 by john11668.
- Thank you received: 7490
22 Apr 2022 09:29 #240871
Replied by tommylight on topic New install of Mesa 7i92 on TCL lathe
Did you check the link i posted?
it describes in detail how to set up Mint.
The following user(s) said Thank You: john11668
- john11668
22 Apr 2022 09:50 #240872
by john11668
I did tommy but the big warning in red seems to put me in another dark spot .
I have already(after earlier instructions ) edited the file /etc/network/interfaces .
This leaves me wondering whether I need to undo previous changes , and of course the question arises how to do that.
Having embarked on that route is there maybe an alternative that avoids the need for retreat.
- ALittleOffTheRails
- Visitor
22 Apr 2022 10:06 #240873
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic New install of Mesa 7i92 on TCL lathe
Mint Version
I've never edited the /etc/network/interfaces file when using Mint. I just click on the Network icon on the taskbar, RH side near the clock, and edit using the dialogs. More info is in the link I supplied for Network config for Mint.
cat /etc/lsb-releaseI've never edited the /etc/network/interfaces file when using Mint. I just click on the Network icon on the taskbar, RH side near the clock, and edit using the dialogs. More info is in the link I supplied for Network config for Mint.
- john11668
22 Apr 2022 10:16 #240875
by john11668
Thanks for that "linuxhint" too ALittleOffTheRails.
Will try to follow that one tonight when i get back to base .
22 Apr 2022 10:23 #240876
OK, i have no idea how to revert back from that, although i would like to think that deleting the parts that were added should do the trick.
- Visitor
22 Apr 2022 10:49 #240879
Mint 19.2
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopbackPlease Log in or Create an account to join the conversation.
- Clive S
- Thank you received: 486
22 Apr 2022 16:43 #240894
by Clive S
Replied by Clive S on topic New install of Mesa 7i92 on TCL lathe
Are you trying to get wifi working
I think you said you have bought a dongle, What did you get?
I gave a link in forum.linuxcnc.org/39-pncconf/45604-new-...athe?start=20#240327
you would plug that into a usb port.
If I am off the mark just forget my post
- john11668
22 Apr 2022 16:48 #240895
by john11668
Menu / Network brings up a single folder called windows network trying to open this
Leads to error message "Unable to mount location , Failed to retrieve share list from server : no such file or directory,
My system is Mint 19.3 triciaWhat version of Mint, it's always good to know.
So would it be safe to assume that this "adapter" is a USB to LAN adapter ?
Yes
If you could supply as much info as possible regarding the USB to LAN adapter that would be great. It will help determining if a driver is available.
Prefably the output of the following.[/code]sudo lsusb [color=#d35400]Result Bus nos 001--005 Only the following looks promising Bus 001 Device 002: ID Obda:8151 Realtek semiconductor corp. RTL8151 Adapteon Business Mobile Networks BV[/color] If the command is not found you will need to install usbutils: [code]sudo apt-get install usbutils [color=#d35400]Even after this I still get not found [/color] Once you get to a stage where you have more than one network adapter (this means any combination of Wifi\Ehernet or whatever) you need to tell the system how to configure each adapter, it does not know automagically how to do that. Just remember to keep your Mesa card and home network on different segments. ie Mesa may be on 10.10.10.xxx and your Home network on 192.168.1.xxx Only the home network with require the use of a Gateway & DNS server, the Mesa network requires neither. This is an article on how to setup a network using Mint. Now remember not to change the network settings for the network that connects to your MESA card. This may or may not pertain to your Version of Linux Mint. https://linuxhint.com/network-configuration-linux-mint/ Remember also that if you have a spare PCi\PCIe slot inside the computer you do not need to use a USB adapter, there is the option to use a appropriate internal network adapter
- john11668
22 Apr 2022 17:53 #240902
by john11668
2700Mbps Wireless USB WiFi Adapter Dongle LAN 802.11BGN 2.4/ 5.8Ghz 5G Dual Band | eBay
but still waiting for it to arrive , so yesterday bought a lan adaptor to USB from local shop. Anything to get me going.
I just could not get going with no facility to download on this machine .
I presume I would still have to set up a connection even with dongle but as you can see from recent post menu / network leads me nowhere.
I dont care what I have to do to connect to internet , but every prospect seems to lead me to a dead end
I ordered this one Clive ,John
