LinuxCNC 2.9 RPi - PNCconf error
3 years 7 months ago #267759 by cmorley
yes you need to run make after.
3 years 7 months ago #267760 by mor
Okay, it's compiling now. So I just remake the .deb and install all over again?
I'll do that and let you know how it goes. Thanks again for all the help!
3 years 7 months ago #267761 by cmorley
Sorry - you are compiling a deb? - well that the long way.
I assumed you were using a RIP when you said you compiled.
In future you can edit the file directly - they are just in different locations when installed.
Please confirm that the fix worked or any new error message if it did not.
3 years 7 months ago #267762 by mor
I’ll look into RIP; I just compiled and built a package and installed? image missing /media/kunena/emoticons/silly.png
3 years 7 months ago #267763 by phillc54
My PI4 has finally finished updating and FWIW I don't see the issue on a RIP build. I probably have an older kernel (5.15.27-rt35-v8), not sure if that would make a difference.
The error I posted before only happens if I select the 7i96s_7i74 firmware which seems to be the default.
3 years 7 months ago #267764 by cmorley
RIP is good if you need/want quick/experimental code changes.
installing with a deb is very common, as it's easy to install and get up running.
Compiling a deb seems the worst of both, but it doesn't really mater - what ever works for you.
Time to create page: 0.152 seconds
