Index homing Mesa 7i96s
3 years 6 months ago #268319 by hsn
Replied by hsn on topic Index homing Mesa 7i96s
This is awesome. Would it be possible to build a firmware which replaces the encoder with the index inputs on the 7i96s?
Unfortunately I already have a separate use case for the isolated I/O but I won't be needing an encoder on this machine.
3 years 6 months ago #268340 by PCW
Replied by PCW on topic Index homing Mesa 7i96s
Its possible (say encoder A,B,IDX = Stepgen 0,1,2 index)
I'll try and get to this some time this week
The following user(s) said Thank You: hsn
3 years 6 months ago #268529 by PCW
File Name: 7i96sd_esdid.zip
File Size:249.73 KB
The following user(s) said Thank You: tommylight, hsn
3 years 6 months ago #268565 by PCW
I should note that there is also firmware that puts all 5 index inputs
on P1 (but of course these inputs are not really suitable for field wiring)
3 years 4 months ago #273639 by besriworld
Replied by besriworld on topic Index homing Mesa 7i96s
Hello,
can you share the magic you do with editing the file? I have the output of the encoder from the servo driver. But many threads mention lag in different servo drivers. I'm thinking of leaving the PID control to the servo drive.
If you can share an example. Thanks!
3 years 4 months ago #273641 by PCW
Not sure what you are asking for...
If this is about using stepgen index for homing, the hal connections
are identical to a system using encoder index for homing except that you use
the stepgen index enable pin in the hal file rather than the encoder index enable
pin
Note that you will always use the local PID in HAL with Mesa stepgen hardware
Time to create page: 0.069 seconds
