Index homing Mesa 7i96s
3 years 9 months ago - 3 years 9 months ago #261306 by routerman22
Replied by routerman22 on topic Index homing Mesa 7i96s
But it is doable without needing custom fw on the mesa?
editing the hal file is not an issue for me. Other than figuring out what needs to be changed.
Last edit: 3 years 9 months ago by routerman22.
3 years 9 months ago - 3 years 9 months ago #261316 by PCW
Replied by PCW on topic Index homing Mesa 7i96s
It needs custom firmware or a specific component that simulates index behaviour
I think there is a thread where this was discussed, searching for stepgen index might find it
The disadvantage of using a component to simulate index behavior is that it
will typically miss index pulses shorter than 1 servo thread in length.
I don't mind making special firmware for this if you can live with the loss of 4 isolated inputs
Last edit: 3 years 9 months ago by PCW.
The following user(s) said Thank You: routerman22
3 years 9 months ago - 3 years 9 months ago #261335 by routerman22
I have a few friends that also need this. When doing index homing the velocity is very low so i dont think missing the pulse is an issue. That would be amazing!
Out of interest, what makes this method so slow? I assume that the "proper" encoder method responses faster?
3 years 9 months ago - 3 years 9 months ago #261361 by PCW
If you use the stepgen + index firmware, it works identically to homing to index
with an encoder and can detect short index pulses (sub microsecond)
If you use a special component to do this, it will be limited to detecting pulses
longer than 1 servo thread period.
Here is a link to a thread with a users hal component that implements stepgen homing to
index:
forum.linuxcnc.org/24-hal-components/463...der-m19-g33-1#246815
Last edit: 3 years 9 months ago by PCW. Reason: formatting
3 years 9 months ago #261430 by routerman22
most likely I'll just by an expansion board to keep it simple. For the 100 bucks or so it is not worth making a super custom config. Thank you anyway!
3 years 9 months ago #261531 by PCW
Here is firmware for a 7I96S + 7I85 (not 7I85S) with stepgen index:
File Name: 7i96s_7i85dsdi.zip
File Size:291.8 KB
The 7I85 encoder index inputs can be stepgen or encoder indexes
