New update .I can manually create a bit file . But it comes with several warning messages and one error
WARNING:Bitgen:284 - Setting next_config_register_write to Disable will cause
the next_config_addr, next_config_new_mode, and next_config_boot_mode options
to be ignored and their respective register writes to be excluded from the
bitstream.
INFO:Bitgen:341 - This design is using one or more 9K Block RAMs (RAMB8BWER).
9K Block RAM initialization data, both user defined and default, requires a
special bit stream format. For more information, please reference Xilinx
Answer Record 39999.
WARNING:PhysDesignRules:367 - The signal
<ahostmot2/makesserialmod.makesserials[0].asserial/processor/StackRam/Mram_RA
M1_RAMD_D1_O> is incomplete. The signal does not drive any load pins in the
design.
M2_RAMD_D1_O> is incomplete. The signal does not drive any load pins in the
design.
INFO:PhysDesignRules:1861 - To achieve optimal frequency synthesis performance
with the CLKFX and CLKFX180 outputs of the DCM comp ClockMult1, consult the
device Data Sheet.
with the CLKFX and CLKFX180 outputs of the DCM comp ClockMult2, consult the
device Data Sheet.
WARNING:PhysDesignRules:2410 - This design is using one or more 9K Block RAMs
(RAMB8BWER). 9K Block RAM initialization data, both user defined and
default, may be incorrect and should not be used. For more information,
please reference Xilinx Answer Record 39999.
FATAL_ERROR:Bitstream:stanbsbitfile.c:3408:1.57 - Incorrect number of bits in
bitstream (18) for FDRI write. For technical support on this issue, please
visit
www.xilinx.com/support
File Name:
log2.txt
File Size:1.91 KB
PS. I loaded the file into the board it seems to work. The multiplexer pins are visible in the HAL
If the board works, the error is not important?
