Index homing Mesa 7i96s
1 year 11 months ago #314963 by GeckoWorks
Replied by GeckoWorks on topic Index homing Mesa 7i96s
File Name: 7i96sd_esdid.zip
File Size:249.73 KB
Hi Peter,
I am the one who just ordered the 7i96s and 7i84u and talked about needing to read four index pulses.
Is this the FW, I would need to make it work?
All best and thanks for the guiding on email, too,
David
1 year 11 months ago #314964 by PCW
Replied by PCW on topic Index homing Mesa 7i96s
Yes, this firmware should work (though would need to be modified to add the fourth axis index input)
The following user(s) said Thank You: GeckoWorks
1 year 11 months ago - 1 year 11 months ago #314965 by GeckoWorks
Index (Z pulse) Homing on Delta Servos
I hope it's OK I add a bit more info to this thread specifically in regards to Delta servos. I bought some used ones quite cheaply. To me, it's a better deal than the no name ones as the Deltas have much better documentation and a proper tuning/setup software. (Actually, I am almost sure at least some of Automation Direct's servo series are rebranded Deltas, too.)
Earlier in the thread PCW mentioned a potential speed issue where the Mesa input may not be fast enough to read the index signal unless the index is somehow slowed down. But perhaps the following tidbit I found will help with this (it's from a different controller manufacturer describing  how to wire up index homing  ):
For proper operation it is necessary to rearrange DELTA drives default settings. Number of pulses of drives’ output encoder – should be shifted to a lower value to ensure adequate INDEX signal pulse length. P1-46 parameter set by default on 2500 pulses – set on 500 pulses per rev or less. This change has no influence on servo drives working precision because their internal procedures work on encoder full accuracy anyway.
PCW also suggested on email that I slow down the homing speed (home to regular limit/home switch can be faster, but then slow down the home to index/Z pulse after that). So, maybe a combination of lowering the pulse value for the encoder and slowing down the home speed a bit is the ticket.
Again, if you have B3s, A2s or perhaps A3s(?) you can try making the servo drives handle the homing routine.
Last edit: 1 year 11 months ago by GeckoWorks.
1 year 11 months ago #314979 by GeckoWorks
Great, thanks.
4th is in the future, no need for it for a while:)
1 year 8 months ago #320903 by GeckoWorks
Hi Peter,
My boards arrived a while back and now, finding some time to dive into this - my first ever - Lcnc install. To recap, I have a 7i96s and the new 7i84u but I am looking to use the servos index pulse for homing. Now, the question is, is there a FW which has both the daughterboard plus the index pulse functionality included? Or would I have to somehow add the 7i84u manually and how would I go about that?
1 year 8 months ago - 3 months 3 weeks ago #320923 by PCW
If by daughtercard you mean the 7I84U, any firmware with a sserial port will do.
(basically any 7I96S firmware that does not use the serial expansion for modbus etc)
Last edit: 3 months 3 weeks ago by PCW.
Time to create page: 0.203 seconds
