Gscreen - a GTK / Glade / Python based screen
14 years 8 months ago #17895 by cmorley
Michael is hosting gscreen on his git repo.
git.mah.priv.at/gitweb/emc2-dev.git
It's still based on master branch.
We added another led to the estop button for machine on.
now push once estop reset
push again machine off
push again estop / machine off
you can hide the pointer and zoom the plot with buttons.
  • mhaberler
  • New Member
  • New Member
14 years 8 months ago #17896 by mhaberler
Replied by mhaberler on topic Re:Gscreen - a GTK / Glade / Python based screen
Ok, idiot question. I installed it - how do I start gscreen?
-m
14 years 8 months ago #17897 by cncbasher
press estop twice
once to reset
once to switch machine on
2 green leds and your good to go
  • mhaberler
  • New Member
  • New Member
14 years 8 months ago #17898 by mhaberler
I mean the command line
$ gscreen <and what goes here?>
-m
14 years 8 months ago #17900 by cncbasher
just change the display entry in your INI file to gscreen
14 years 8 months ago #17901 by cmorley
now you must change the line in the INI file.
under the head [DISPLAY]
look for:
DISPLAY = AXIS
change it to
DISPLAY = gscreen
then run linuxcnc normally and select that config.
It you get a weird number for VO percentage and the screen is too big for the display
add a DEFAULT_VELOCITY = something sane under the [TRAJ] heading
Chris M
Time to create page: 0.105 seconds
