Gscreen - a GTK / Glade / Python based screen
14 years 3 months ago #21589 by andypugh
eto wrote:
/home/cnc/linuxcnc-dev/scripts/realtime: line 159: /home/cnc/linuxcnc-dev/bin/linuxcnc_module_helper: Permission denied
Did you build from source? Did you remember "sudo make setuid"?
14 years 3 months ago #21590 by eto
Post no #21564 list exactly what i did step by step. I assume this is build from source. As i did the steps in terminal i wrote it in the post...
My linux skills don't go much beyond reading the wiki and doing the steps...
14 years 3 months ago #21591 by andypugh
You need to sudo the make setuid step.
(And it appears that you didn't).
14 years 3 months ago #21592 by cmorley
sudo make setuid
it will ask for your password.
Do you see a linuxcnc (run-in-place) under Applications/cnc ?
if no then you will always have to run linuxcnc from the terminal and enter . scripts/rip-environment once before running it the first time.
the command make install-menus is supposed to add the run-in-place entries - it didnn't seem to work for me.
Chris
14 years 3 months ago #21593 by cmorley
Also note if using the linuxcnc launcher, if you look under sample configurations / sim you will find three gscreen examples that will run with no hardware.
14 years 3 months ago #21603 by eto
The make install-menus command does not seem to work.
Also when I run sudo make setuid, the process completes, but if i close the terminal and open a new terminal and type linuxcnc it still launches 2.5, i cannot get it to launch 2.6pre ...
I am stuck.
If I do the rip-environment thing it works and I can get the gscreen sample program to run.
I really want it to run just like the original live cd from the applications menu. How do I accomplish this?
Also is anybody working on a touchscreen pendant control? I was hoping that under jogging mode button you would get an onscreen pendant style jogging controller similar to what Mach3 has...
Thanks for the support.
Time to create page: 0.303 seconds
