Gscreen - a GTK / Glade / Python based screen
- tjamscad
13 years 9 months ago #28935
by tjamscad
That could have been it. I just rebuild LinuxCNC when something goes wrong. I have a script file I run in termninal and it does the work.
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
cmorley wrote: ahh you made a separate config to work in.
You need to copy the industrial.glade and industrial_handler.py file to your personal config folder.
i don't think i did anything to the INI file...
I think that should do it.
- Thank you received: 2181
13 years 9 months ago #28944
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
ok I added an offset page to Gscreen.
I guess it's kinda boring looking but it does show ALL the offsets.
It's a gladeVCP widget too if anyone is building their own stuff.
I see I forgot to give the tooledit page the option to change metric systems... ill get that later I guess.
- tjamscad
13 years 9 months ago #29026
by tjamscad
Chris,
1. The at speed indicator is still green before it is set, please make it black unless it is at speed.
2. In program mode the EDIT doesn't toggle to EXIT when edit is selected.
3. MDI can't have multiple lines of commands because of LinuxCNC right?
- BigJohnT
- Thank you received: 994
13 years 9 months ago #29028
by BigJohnT
You could do it like my DX-32 does you enter all the lines of G code you want into the MDI window and it just creates a file MDI.TXT (it uses the TXT extension) and runs that.
Replied by BigJohnT on topic Gscreen - a GTK / Glade / Python based screen
tjamscad wrote: Chris,
- newbynobi
- Thank you received: 394
13 years 9 months ago #29033
by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
Hallo Chris,
I just took a look to your "Offset Page" Because I was thinking about that too.
I wonder, why you list the coordinate systems in rows and the coordinates in lines,
while in the tool editor tab it is viceversa.
I suggest to get an uniform layout for both.
And there is another think I cant understand, please make the following:
- Emergency off
- Machine on
- home all axis
- jog all axis around and then Zero Origin for all axis
- change to auto mode
- load examples spiral.ngc
- go back to manual mode
- jog to an other position, lets say go down 20 mm or 1 inch with Z
- Say cero origin
- go back to auto mode
- run the program
and then wonder where gremlin paints the tool path.
Regards Norbert
- Emergency off
- Machine on
- home all axis
- Say cero origin
- run the program
Regards Norbert
- tjamscad
13 years 9 months ago #29034
by tjamscad
John,
Are you saying that gscreen could create a file when entering multiple lines of g-code or that you could create a seprate file and then run it?
Time to create page: 0.693 seconds
