Gscreen - a GTK / Glade / Python based screen
13 years 9 months ago - 13 years 9 months ago #29137 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Chris,
What file is the main file? I mean what calls all your extra files to come play? How is gscreen structured?
I also noticed that on the spindle section the "FWD" is shown as selected but I didnt select anything. It was just after turning it on.
Last edit: 13 years 9 months ago by tjamscad.
13 years 9 months ago - 13 years 9 months ago #29148 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
The spindle direction buttons 'toogle' either fwd or reverse, so one will always be selected.
In this way when you push start, you will know what way it will turn.
gscreen.py is the Main file.
It has 'helper' files:
mdi.py
preference.py
emc_interface.py
and the stock screen file, gscreen,glade
These are found in /src/emc/usr_intf/gscreen in a compiled run-in-place linuxcnc.
Then there can be 'local' (local as in the users config with the HAL files) custom screen files.
These can be somename_hander,py and/or somename.glade
For instance the industrial screen is defined in these 'local' files. They must be put in every cofig folder that you want industrial in.
This is different from all other linuxcnc screens. There you just change the DISPLAY= name in the INI file and the new screen shows up.
This works with Gscreen too but you will always get the stock screen that way.
Chris M
Last edit: 13 years 9 months ago by cmorley.
13 years 9 months ago #29158 by cmorley
newbynobi wrote: Hallo Chris,
I just managed this, I had to open gscreen and in preferences disable the aux screen, thats it.
So the preferences are taken in care even if I start from a different config folder.
This can confuse operators!
Regards Norbert
Ok Norbert:
You can specify a preference file path in the INI under the [DISPLAY] heading
PREFERENCE_FILE_PATH=
If it's missing, it will use the default ~/.gscreen_preferences
I also fixed the plot reloading problem
oh and industrial now changes the edit button text
Chris M
13 years 9 months ago #29196 by karlkec
Replied by karlkec on topic Gscreen - a GTK / Glade / Python based screen
Hi Chris,
Spent more time on the mill with gscreen. Some comments:
1. If I'm running a program and press "Set Override", the Position, G Codes Active, and Status areas of the screen become greyed out so itt's harder to see the override being adjusted, and to see the axis positions.
2. When first entering MDI mode and bringing up the Onboard keyboard, could the cursor be automatically placed in the MDI entry field? This entry field is small and hard to select using the touchscreen. I think probably this field should be the active one anytime MDI mode is active.
3, Also, after a block is executed in MDI mode the text remains in the entry field. This requires clearing out the text before entering a new MDI command, which is hard to do with the touchscreen. Could the entry field be cleared after it is executed.
4. Double-touching the spinbox in the upper right using the touchscreen sometimes brings up the numeric entry widget and sometimes not. With the touchscreen it would be nice to always bring it up when the spinbox is double-touched.
I'm starting to work on customizing your industrial screen. I have my own config directory outside the development tree, and have made symlinks to industrial.glade and industrial_haldler.py in the development tree. Can I create a new git branch in the development tree for my changes and rebase to pick up your changes? Or is that asking for trouble later on?
Also, do you know of a way to push my changes to my own git server so I can pull them to my other machines, yet get your gscreen updates too?
Thanks.
Karl
13 years 9 months ago - 13 years 9 months ago #29201 by cmorley
karlkec wrote: Hi Chris,
Ok yes I was being lazy :) It was easier to make the whole box greyed out then just all the buttons- I can work on that,
Yes i should be able to set the focus to the MDI entry
This is a separate widget that I didn't make but have tinkered with, I can see what I can do
You must have the pointer still showing. If you hide the pointer then a single click will bring up the numeric entry widget.
If you show the pointer then a double click brings it up. double clicking with a touch screen, as you have seen, is not 100% reliable.
It's done differently so people with a keyboard can click the spinbox once and then type - it's quicker
Thanks.
Karl
You should create your own local branch based from master.
Make sure your on master:
git checkout master
pull to make sure your current:
git pull
then make your own branch (topic name can be anything)
git branch topic master
If you 'gitk' - you will see your new branch on top
if you 'git branch' you will see your new branch name
Now make your changes to Gscreen's file then commit the changes
if you 'gitk' you will see these commits
If you wish to merge master back in from time to time use:
git merge origin/master
and be prepared to fix conflics.
This is just the very basics. I hesitate to say much more since I wish to tell no lies :)
You should ask on the maillist where the git experts live!
Please keep us posted on your changes, so they can possibly be incorporated
You should see Norbert's screen - it is so different, based on Mocca's look if you know Mocca.
Now I know why all those Mach guys were bummed when they realized the screen was difficult to change in linuxcnc.
It's kinda fun!
Chris M
13 years 9 months ago #29223 by tjamscad
cmorley wrote: The spindle direction buttons 'toogle' either fwd or reverse, so one will always be selected.
mdi.py
preference.py
emc_interface.py
Chris M
Thanks Chris, That's alot to take in but in time i'm sure i will get it.
Time to create page: 5.297 seconds
