Gscreen - a GTK / Glade / Python based screen
13 years 9 months ago - 13 years 9 months ago #29036 by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
Hallo Chris,
it's again me.
I just changed some thinks in moccapy and started it to check my changes.
It seems you have changed something within gscreen, because now the aux screen opends by himself.
I didn't change anything within my ini file, but the screen with the spindle indicator and the small gremlin opens.
I am speeking over gscreen2.glade window.
This is strange for me.
I just managed this, I had to open gscreen and in preferences disable the aux screen, thats it.
So the preferences are taken in care even if I start from a different config folder.
This can confuse operators!
Regards Norbert
Last edit: 13 years 9 months ago by newbynobi.
13 years 9 months ago #29064 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
tjamscad wrote: Chris,
1. The at speed indicator is still green before it is set, please make it black unless it is at speed.
2. In program mode the EDIT doesn't toggle to EXIT when edit is selected.
3. MDI can't have multiple lines of commands because of LinuxCNC right?
1) it IS at speed - the speed requested speed is zero so when the spindle is zero the LED goes green.
I'll have to figure out how to combine that with something else to make it black when turned off.
2) oh yes sorry forgot.
3) As far as I know.
Chris M
13 years 9 months ago #29065 by cmorley
newbynobi wrote: Hallo Chris,
Regards Norbert
Yes the preference file is written to your home folder.
It is used by any/all Gscreen programs.
It could be possible to specify a preference filename in the INI.
so then you could have multiple screens on one computer.
I just wonder how often this is really necessary...?
13 years 9 months ago #29086 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Yes that makes sense, I just didnt think of "0" as speed.
13 years 9 months ago - 13 years 9 months ago #29094 by BigJohnT
Replied by BigJohnT on topic Gscreen - a GTK / Glade / Python based screen
I did something like if speed > 0 then check the at speed... I forget exactly where I did that at.
Last edit: 13 years 9 months ago by BigJohnT.
13 years 9 months ago #29111 by cmorley
I just took a look to your "Offset Page" Because I was thinking about that too.
I wonder, why you list the coordinate systems in rows and the coordinates in lines,
while in the tool editor tab it is viceversa.
I suggest to get an uniform layout for both.
Ahh yes, You are surely right, I think maybe AXES should go left to right on both screens ??
And there is another think I cant understand, please make the following:
- Emergency off
- Machine on
- home all axis
- jog all axis around and then Zero Origin for all axis
- change to auto mode
- load examples spiral.ngc
- go back to manual mode
- jog to an other position, lets say go down 20 mm or 1 inch with Z
- Say cero origin
- go back to auto mode
- run the program
and then wonder where gremlin paints the tool path.
Regards Norbert
Yep that's a regression I missed. I need to tell gremlin to reload the plot after a coordinate offsets change.
I did this by using a button that was connected to hal_action_reload.
later I moved the button and remoced the connect to hal_action_reload.
I'll fix it by calling the action directly..
Thanks for pointing them out !
Chris M
Time to create page: 5.723 seconds
