Gscreen - a GTK / Glade / Python based screen
- LAIR82
- Thank you received: 3
03 Jul 2013 23:56 #36281
by LAIR82
Replied by LAIR82 on topic Gscreen - a GTK / Glade / Python based screen
It is a hidden file, in your home directory.
Go to "Places" and click "Home Folder", then click "View" and select "Show Hidden Files".
You should find a file named ".gscreen_preferences", open that up and near the bottom you will see "embedded_keyboard=True", set that to false.
Rick
Rick
The following user(s) said Thank You: tjamscad
- tjamscad
04 Jul 2013 00:12 #36283
by tjamscad
Does this hide the button for keyboard toggle as well?
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Rick
- newbynobi
- Thank you received: 394
04 Jul 2013 01:32 #36288
by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
No, it will not hide the button. If you wish to hide also the button, you will have to edit the glade file and set the visible property of the corresponding button too false.
Norbert
Norbert
- tjamscad
05 Jul 2013 21:13 #36340
by tjamscad
Rick,
Are you running gscreen on a mill or lathe?
- tjamscad
05 Jul 2013 21:16 #36341
by tjamscad
Chris,
I have been toying with the idea for porttrait mode. I want to use a 19" or larger touch screen that would allow the bottom section to be the keyboard. Is this even possible?
- LAIR82
05 Jul 2013 22:11 #36344
by LAIR82
We have two lathes running Gscreen, and soon to be 3, we will be starting our third retrofit in the next 2-3 weeks hopefully
Rick
Rick
- tjamscad
06 Jul 2013 04:27 #36347
by tjamscad
Wow! is seems like only yesterday you were introducing your self on the fourm.
What hal pins are availble in gscreen? I am updated from touchy and just replaced the touchy with gscreen and it doesnt like it.
net X-jog-enable gscreen.jog.wheel.x axis.0.jog-enable
net Y-jog-enable gscreen.jog.wheel.y axis.1.jog-enable
net Z-jog-enable gscreen.jog.wheel.z axis.2.jog-enable
net cycle-start ppmc.0.din.32.in-not => gscreen.cycle-start and2.2.in0
net feed-hold-toggle ppmc.0.din.33.in => toggle.0.in
net feed-hold toggle.0.out => gscreen.single-block and2.2.in1
net toggle-abort and2.2.out => gscreen.abort
net XPosJog ppmc.0.din.37.in-not gscreen.jog.continuous.x.positive
net XNegJog ppmc.0.din.36.in-not gscreen.jog.continuous.x.negative
net YPosJog ppmc.0.din.38.in-not gscreen.jog.continuous.y.positive
net YNegJog ppmc.0.din.39.in-not gscreen.jog.continuous.y.negative
net ZPosJog ppmc.0.din.40.in-not gscreen.jog.continuous.z.positive
net ZNegJog ppmc.0.din.45.in-not gscreen.jog.continuous.z.negative
net ZRetract ppmc.0.din.30.in-not gscreen.quill-up
Rick
- Thank you received: 2181
06 Jul 2013 08:12 #36350
try this (works on my laptop)
go to System / preferences / monitors
on the monitor screen there should be a checkbox for show monitors in panel - check it.
you should see a monitor appear in the panel. click it.
If you graphics card supports it you should see options to rotate the screen.
If that doesn't work then there are probably other ways - that you would need to research on the web.
Chris M
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
Chris,
Chris M
06 Jul 2013 08:17 #36351
When you first start Gscreen, on the debug page, in the terminal are the current Gscreen pins.
Whether they do what you want .....
Chris M
PS yes the separate panel for controls would be just for testing .
Chris M
Chris M
Chris M
- tjamscad
08 Jul 2013 19:54 #36397
by tjamscad
How do I add pins if there not there?
Time to create page: 1.327 seconds
