Gscreen - a GTK / Glade / Python based screen
- tjamscad
In what condition do the "cooridnate system" and "tool set" become active in the Indrustrial skin?
- Thank you received: 2181
coordinate system is available in the setup page - Its really just a convenience button.
select it and press the up or down buttons to select one of the nine user systems. the current system is displayed in the upper right.
You must select an axis before the 'tool set' button.
- tjamscad
cmorley wrote: you need to be homed for both buttons to work.
So then the "tool set" is a probe tool setter?
- LAIR82
- Thank you received: 3
For instance when you touch off in the X and press Tool Set, a box pops up and you enter the appropriate value, then when you press enter, it applys that value to your tool table.
Rick
- tjamscad
LAIR82 wrote: Tool Set is used for touching tools off on your workpiece,
Rick
Ok, thanks Haas calls that tool offset measure.
- tjamscad
