Gscreen - a GTK / Glade / Python based screen
13 years 3 months ago #36632 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
Can you post the INI file.
I bet you didn't add the jog increment entry to the INI (TOUCY doesn't use it)
As for jogging - did you remember to click the on screen button 'jog' to enable jogging?
Chris M
13 years 3 months ago #36633 by cmorley
Yes not having something like :
INCREMENTS = .001 in, .01 in, 0.1 in, continuous
under the [DISPLAY] heading will cause the jog increments error. (it should mention the missing entry in the alarm page.)
I will fix it to add sane defaults.
For jogging the button is called 'jogging mode' and you must select an axis as well.
Chris
13 years 3 months ago #36634 by cmorley
I pushed the increments fix, changed to the new layout of offsetpage widget and move the onboard keyboard to the center tab.
Chris M
13 years 3 months ago #36647 by cmorley
I almost have the run-from-line use cycle start to start figured out.
Well actually it's figure out just need more testing for corner cases.
Chris M
13 years 3 months ago #36669 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
cmorley wrote: Can you post the INI file.
Chris M
Yes, I selected the Jog button and the axis.
13 years 3 months ago #36671 by tjamscad
Chris M
You are correct once again. No "INCREMENTS" in the ini file.
Time to create page: 0.158 seconds
