Gscreen - a GTK / Glade / Python based screen
13 years 3 months ago - 13 years 3 months ago #36751 by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Last edit: 13 years 3 months ago by tjamscad.
13 years 3 months ago #36752 by tjamscad
This is why the operators dont like the picture show (gremlen). This is just a small 3 axis part and it already looks like spegitti.
13 years 3 months ago #36757 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
tjamscad wrote: Chris,
With the onscreen keyboard can it come in below the MDI command box? With it being above my hand covers the line i am typing.
I also dont get the keyboard on the tool edit or offset pages.
Could you also make it so the keyboard button is selectable. It doesnt change i cant tell when the keyboard is shown or not shown. The button doesnt change it only works as a highlight.
The spare button on the side panel can you make that a calulator?
When running a program it would be nice if program edit was avaible when feed hold is selected.
When feed hold is selected cycle start should also be an option to start the cycle back. It was not clear how to start a program feed hold was selected.
Can you add a seperator bar or something on the tool edit page between the diameter and comments section?
When pressing enter on the run at line dialog I think the dialog box should go away.
Getting the keyboard to show for the offsetsage ad tooledit page is quite a bit of work so will take a while. - I bet that's why i had moved the keyboard to the side for a while.
Having the keyboard button show status is possible. It;s also possible to get it out of sync with the keyboard. that's why it is the way it is. Something to work on later.
I can add a calculator yes.
If you edit a program, you must reload it into linuxcnc to use the edits. (that's linuxcnc not Gscreen choice)
If you reload it it, it cancels feedhold and will restart at the beginning again.
So editing while in feed hold is not useful as linuxcnc is now.
Starting a feed hold held program:
So pressing feedhold -> stop the feed, cycle start -> start it again
Also I think single step needs some work.
I'm thinking pressing single step on a running program should feedhold at the end of that line, then pressing cycle start feeds each next line.
un-pressing single step should immediately begin to move ? or should it put it in feed hold so you have to press cycle start again ?
The separator in tool editor is programmically there - must be a bug it doesn't show. - I'll see what i can do.
Pressing enter doesn't close the dialog because that is a feature.
When I press cycle start I want to know what line it will start on.
Normally this is the beginning on a program that isn't running.
With the dialog showing, I have a visual clue that it is going to start somewhere else.
Even if the operator gets pulled from the machine and comes back later or someone else has to continue it - they will know where it will start from.
Chris M
13 years 3 months ago - 13 years 3 months ago #36758 by cmorley
The pics are linuxcnc showing program errors.
Chris M
Last edit: 13 years 3 months ago by cmorley.
13 years 3 months ago #36759 by cmorley
tjamscad wrote: This is why the operators dont like the picture show (gremlen). This is just a small 3 axis part and it already looks like spegitti.
It's possible to turn off different plot options, such as rapid moves etc - might make it easier to see.
probably could get it down to feed moves and current tool position .
Chris M
13 years 3 months ago #36769 by tjamscad
Chris M
Single block should leave feed hold on until you press cycle start
Time to create page: 2.105 seconds
