Lathe Macros
12 years 10 months ago #42073 by strykerg
Replied by strykerg on topic Lathe Macros
Andy,
I installed it (version 3.6.7) but I still got the same error.
I think I missed something obvious and basic, no idea what tho
12 years 10 months ago #42074 by cmorley
Replied by cmorley on topic Lathe Macros
Strykerg
What Screen are you using ?
If it's Gscreen or Gmoccapy the INI entry:
EMBED_TAB_NAME=Cycles
is wrong.
I can give more info when I know what screen your using.
The warning about Libglade is normal.
Chris M
12 years 10 months ago - 12 years 10 months ago #42075 by strykerg
I am using Axis.
is there anymore info I can provide? error log:
File Name: error.txt
File Size:3.29 KB
Last edit: 12 years 10 months ago by strykerg.
12 years 10 months ago #42079 by andypugh
Replied by andypugh on topic Lathe Macros
I am not sure what the problem is that you are seeing.
I think there is a problem queueing up to confound you later, that the G-code relies on reading HAL pins directly and, that is a feature only available in Master. (which reports itself as 2.6, but isn't)
It is possible to install Master from the buildbot, it might even solve the current problem. (I have been using it for many months with no issues)
12 years 10 months ago #42101 by strykerg
sounds complicated for my Linux knowledge.
I just wanted to give it a try it looks really neat. Your old lathe macros work fine for me, the only annoying thing is keying in the values in the spinboxes.
12 years 10 months ago #42103 by andypugh
Switching to using the development version is just a case of following the instructions at buildbot.linuxcnc.org
You can make the spinbox a bit friendlier by swapping pyvcp_widgets.py on your system with this file here:
www.bodgesoc.org/lathe/pyvcp_widgets.py
That allows you to press "enter" to confirm a value, rather than toggling up-down on the arrows.
(I am not entirely sure where the file lives, and I am not on a LinuxCNC system at the moment. Probably /usr/bin )
Time to create page: 0.532 seconds
