I use it a lot, so I can only conclude that I must have made a change and not updated the version here.strykerg wrote: the other thing that didn't quite work well was boring, the tool rapids out towards the work instead of inside the bore.
It should actually work just as well for American standard threads, as the geometry is identical. It won;t work for Whitworth, BA, Panzergewinde etc.I like the idea of just putting in the thread diameter however its not possible to turn non metric threads that way
Each Spinbox has an "Adjustment" that contains the max and min. (several spinboxes can share an "adjustment", but that seems to mean that they share the same value too, which can actually be useful at times)just one question - where the hell in Glade do you change the spinboxes' maximum value from? i've been looking all morning and comparing with other spinboxes but no luck!
yes but in Glade , when I open the properties window of a specific spinbox I can't find min max values. the reason I want to do this is that for testing I want to change from feed per rev to feed per min and the spinbox is limited to 2 (so that I can test with the spindle motor off) - I also am curious because I did use glade a few years ago and I am sure there is a min max value somewhere as you are statingEach Spinbox has an "Adjustment" that contains the max and min. (several spinboxes can share an "adjustment", but that seems to mean that they share the same value too, which can actually be useful at times)
strykerg wrote: but in Glade , when I open the properties window of a specific spinbox I can't find min max values.
mariusl wrote: where is the best place to put the ngc and png files that goes with your macros?
