andypugh wrote: I know what the problem might be. The subs run in CSS and feed-per-rev mode. Do you have a spindle encoder?
mariusl wrote: Not yet it is on the to-do list. So it never get spindle up to speed condition right?
mariusl wrote: The boring routine has a bad behaviour. If you cut an ID with a taper, the retract position is calculated from the start of the taper and causes the tool to plunge into the taper and remove it on the way out. The retract should be calculated from the end diameter of the taper.
