Lathe Macros
12 years 4 months ago #47873 by mariusl
Replied by mariusl on topic Lathe Macros
I have them in my config folder. The quirks are ok except for the first one as you said.
The main problem though is that no code is posted. The message comes up but no code. I am trying to get it to work with Gscreen. Have you tried that before?
Regards
Marius
www.bluearccnc.com
12 years 4 months ago #47882 by andypugh
Replied by andypugh on topic Lathe Macros
mariusl wrote: The main problem though is that no code is posted?
I don't know what you mean?
The tabs just run fixed parametric G-code routines. They don't generate G-code.
12 years 4 months ago #47886 by mariusl
I thought that you post gcode to the screen like NGCGUI does. It did nothing so I checked on the auto screen to see what the code looks like but saw no code. Hence my confusion :)
Regards
Marius
www.bluearccnc.com
12 years 4 months ago #47887 by andypugh
mariusl wrote: I thought that you post gcode to the screen like NGCGUI does. It did nothing so I checked on the auto screen to see what the code looks like but saw no code. Hence my confusion :)
In the Axis interface it is actually a little strange, the G-code preview window acts like it is running a program, and highlights lines in the currently loaded file, but that isn't actually the code that is running :-)
12 years 4 months ago #47891 by mariusl
Ah I see. Now I have learnt something new again. I am busy setting up the jogging of the lathe and once that is done I will test the macros on the lathe itself with Gscreen.
Regards
Marius
www.bluearccnc.com
12 years 4 months ago #47908 by mariusl
Andy
Have ypu tried this with Gscreen. I am getting strange behaviour. When I run the turn macro it says that the file turning.ngc cannot be found although it is in the config folder.
I am running RIP with all my paths set to the right locations in the RIP folder but when I load a file in Auto mode, it points to the 2.5.4 nc_files directory. I dont have that set anywhere.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.179 seconds
