mariusl wrote: Hi Andy
Is the threading function TPI only or is there a way to enter a metric pitch.
I wanted to cut a 8mm thread with a pitch of 1,25mm but got a 1,25 TPI instead
As my lathe is set up as metric then if I put "1.25" in the box I get a 1.25 mm pitch thread.mariusl wrote: Is the threading function TPI only or is there a way to enter a metric pitch.
The cycles all start from where the machine is when the "go" button is pressed, so if I decide to interrupt the sequence I just jog to a suitable starting point and press the button again.Also, is there a way to recover the original setting if the code was stopped midway? If not how would you do it in practise
andypugh wrote: However, if you put in the feature in post 48403 further up the page then you can type "25tpi" and it will automatically change to "1.016" and then if you type "mm" it will change to "0.04"
