As my lathe is set up as metric then if I put "1.25" in the box I get a 1.25 mm pitch thread.
If your lathe is set up for imperial then you will get a 1.25" pitch.
However, if you put in the feature in post 48403 further up the page then you can type "25tpi" and it will automatically change to "1.016" and then if you type "mm" it will change to "0.04"
mariusl wrote: If I use the spinbox feature and enter 1.25mm it converts it to 0.0492 but then I get an error " In G76 K must be greater than J" You have J set at 0.2 so how does K get greater?
Must I modify the sub to use this in any way?
