mariusl wrote: The lathe is setup in mm - G21 present
There seem to be an index enable pulse that occurs every revelution of the chuck.
mariusl wrote: Very difficult to say as it changes all the time. I have a very aggressive lowpass filter on the feedback.
What I just noticed is that the feedrate remains the same no matter what spindle speed I select. Surely that does not seem right?
mariusl wrote: Will this feature be included in production (2.6.x) at any stage or will I have to make sure that I apply a fix after any update?
You shouldn't have any filtering between encoder position and motion.spindle-revs.
Also you need to make sure that motion.spindle-revs is spindle _position_ not spindle _speed_
From my point of view the extra characters are just short-cuts "in" for "convert from inches to mm" and "mm" for "convert from mm to inches" but others didn't see it that way
