QT C++ code samples
7 years 3 months ago #139670 by phillc54
Replied by phillc54 on topic QT C++ code samples
I cloned my machine and went to download QT.
They are kidding, 8.8Gb. My whole machine is only 16Gb.
Surely there is a simpler way.
7 years 3 months ago - 7 years 3 months ago #139728 by Grotius
Replied by Grotius on topic QT C++ code samples
Hi Phill,
Nice work !!!
When the time is fertig, a auto installer will be made... Just like Qt.
Soon the command line installer will be fertig.
I made some progress with the contour recognize algoritme finally.
There was a tiny bug that was very hard to spot in the front end class. The swapping class.
This class looks for matching start and end point. If not, it swaps the points to a match.
Tomorrow i will try to add the open contours and circles to this.
The example works nice for closed contours now. I can make more progress now. Up to the next gear...
Soon i can make a algoritme for nesting. I will start that item when i think the basic's are more or less hufter proof.
DxfDecoder example of optimized closed contours :
Axis gui :
Latest version :
we.tl/t-mbU0YfBKBW
After unpack, type in terminal : ./DxfDecoder
Qt must be installed for now.
For example a non optimized contour. Pure base array (raw gcode output)
It forget's the corner arc's, it will do everything non logic. It stops half way the left above contour and goes to the right above
contour. Haha....
Last edit: 7 years 3 months ago by Grotius.
The following user(s) said Thank You: phillc54, tommylight
7 years 3 months ago #139731 by rodw
Replied by rodw on topic QT C++ code samples
This really is great work you are doing Grotius!
7 years 3 months ago #139734 by tommylight
Replied by tommylight on topic QT C++ code samples
Somehow, every job he does is great.
7 years 3 months ago - 7 years 3 months ago #139737 by Grotius
Thanks so much for your kind words.
In my life, i want to meet you both.
@Tommy,
I have one job that was at high court 2 times this year. It costed me over 7500 dollars.
It is my ex. She blackmailed me several times.
But for the rest i have no problems...
Had many problem's starting with linux. But never give up. The best practice is to do it yourself.
I must think about Phoenix....
Give me your dammnnn config.
What did Phoenix said what you deleted? Maybe we can make a joke of that... B)
@Rodw,
This year i will only write software for open source purposes. That is my full time job for now.
This because i like Linux. And i want to give something back. Money does not interest me.
Later on, when i know more about software, i will think about making a special software application.
High end. Something with hologram's or AI attrack's me.
Realize the opengl is in fact a 2d display. The DxfDecoder is full 3d. It becomes easy for me to make a real 3d hologram at this moment. I am thinking about the hardware...
The following user(s) said Thank You: tommylight, bkt
7 years 3 months ago #139755 by phillc54
I think I will wait till then...
What you have done so far looks great.
Time to create page: 0.324 seconds
