XHC-WHB04B-6 Macro 10 zum Achse Nullen
07 Nov 2019 10:16 #149826 by pl7i92
Replied by pl7i92 on topic XHC-WHB04B-6 Macro 10 zum Achse Nullen
eigentlich ist das -> MDI_COMMAND=(debug,macro10 X Null)
nur der platzhalter für
MDI_COMMAND=G10 L20 P1 X0
tolle zusammenstellung die du dir da gebastelt hast
Pass bitte auf die leerstellen und kommentare auf die hal sollte kompakt bleiben
13 Jul 2024 13:08 - 14 Jul 2024 07:28 #305075 by Anton
Replied by Anton on topic XHC-WHB04B-6 Macro 10 zum Achse Nullen
Hello,
I am a beginner and still have some problems with the signal linking in the HAL.
As shown above, I have managed to zero the axes using button 10 and the rotary knob for axis selection. How can I now set all axes to 0 after selecting axis C with the rotary knob and pressing button 10?
#### Axes Zero with selected axis and button10 ###
loadrt and2 names=and2_X,and2_Y,and2_Z,and2_C
addf and2_X servo-thread
addf and2_Y servo-thread
addf and2_Z servo-thread
addf and2_C servo-thread
net button10 <= whb.button.macro-10
#### X-Axis ####
net pdnt.axis.X.select => and2_X.in0
net button10 => and2_X.in1
net x_zero <= halui.mdi-command-21 <= and2_X.out
#### Y-Axis ####
net pdnt.axis.Y.select => and2_Y.in0
net button10 => and2_Y.in1
net y_zero <= halui.mdi-command-22 <= and2_Y.out
#### Z-Axis ####
net pdnt.axis.Z.select => and2_Z.in0
net button10 => and2_Z.in1
net z_zero <= halui.mdi-command-23 <= and2_Z.out
### Zero all axes if axis C is selected ###
net pdnt.axis.C.select => and2_C.in0
net button10 => and2_C.in1
net zero_all ????
Last edit: 14 Jul 2024 07:28 by Anton.
13 Jul 2024 13:39 #305082 by Aciera
Replied by Aciera on topic XHC-WHB04B-6 Macro 10 zum Achse Nullen
Create a new HAL_COMMAND entry in the ini file:
MDI_COMMAND=G10 L20 P0 X0 Y0 Z0
and call that from your hal:
net zero_all => halui.mdi-command-your_number_here <= and2_C.out
The following user(s) said Thank You: Anton
13 Jul 2024 17:14 #305097 by Anton
Thank you very much for the quick reply!
I had tried to call the MDI commands
halui.mdi-command-21,
halui.mdi-command-22,
halui.mdi-command-23, i.e. to use them again, which did not work.
With a new MDI command, it becomes quite simple.
Moderators: Muecke
Time to create page: 0.388 seconds
