Hello PCW,
I checked the hm2_7i76e.0.packet-error-total and got 57 errors about 45 minutes. Is this too much?
I don't understand these packet losses - (my PC is a lenovo ThinkCentre M92p Mini-PC, Intel Core i5-3470T 2.90 GHz 8GB Ram, in the latency Test I get readings as shown in the photos, first at start, Servo 4000, Base 5608, after 30 minutes surfing, coding in Vcode, doing sth else: servo 82040, Base 24542, I set servo thread in the INI file to 1.600.000.
Kernel release 6.1.0-29-rt-amd64, Kernel Version #1 SMP PREEMPT_RT Debian 6.1.123-1 (2025-01-02)
What do you think?
I did the most Latency tips in this thread:
forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity
- I disabled hyperthreading, power saving, virtualisation, TPM, turbo mode, ACPI, APM, Audio,, kernel isolate core 0 for interrupts - quiet irqaffinity=0 isolcpus=0. I bought a new network controller with RTL_8125 chip, optimize my network connection with sudo ethtool -C eno1 rx-usecs 0 at any system start. Kernel release 6.1.0-29-rt-amd64, Kernel Version #1 SMP PREEMPT_RT Debian 6.1.123-1 (2025-01-02)
Anyways, I dont have servo motors with encoders wired to the MEsa 7i76e, so I cannot calibrate in live mode. I just set the FF2 to 0.0003 as you said. Same results as yesterday, not often but sometimes i get that motor-0-position errors.
Maybe my PC is too slow for a Linux system? Any suggestions?
Thank you so much for your support!
Hanno
(For some reason, I cannot put photos <1MB in this thread...)
