Hey guys, after several delays I got my machine running and I made my first part with it. First part, first problems. The locknut from my driven ball screw came loosened and I got a lot of backlash. I fixed that, then I had problems with my VFD (Hitachi WJ200), and had to send it to the service. Meanwhile, I used a chinese VFD (with filter unit in the line) , that worked fine, but last week I got the known problems with "motor-0-errors. Mostly if the x-axis stopped, turned around, then comes the error. Sometimes it runs several paths, then stopped again. That drives me crazy.
My latency is as good as before, I don't have lost packages, I don't know what to do with it.
Do you have any hints for me to change this problem? I put my actual HAL and INI here.
BTW - I don't understand that kind of error. What makes LCNC to give this error out? There's no connection to the motor's encoders, no feedback nothing what makes sense for me...
Tanks for any help!
Kind regards, Hanno
