- Thank you received: 7491
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
1 year 7 months ago #323320
Replied by tommylight on topic Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
3 Probably because QtDragon does not use the same enable pin as GmoccaPy, although if that is the case, i would really insist on fixing that in QtDragon.
Can you upload config files for both GUI's?
- FraesPaul
- Thank you received: 9
1 year 7 months ago - 1 year 7 months ago #323381
by FraesPaul
Replied by FraesPaul on topic Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Hallo,
vielen Dank für die Antwort.
Hier die beiden Ordner
Hello,
Thank you for your reply.
Here are the two folders
Hello,
Last edit: 1 year 7 months ago by FraesPaul.
- FraesPaul
1 year 7 months ago #323637
by FraesPaul
Have you had time to take a look at my configuration ?
hattest Du schon Zeit mal einen Blick auf meine Konfiguration zu werfen ?3 Probably because QtDragon does not use the same enable pin as GmoccaPy, although if that is the case, i would really insist on fixing that in QtDragon.
1 year 7 months ago #323706
Yes, i checked the files twice but could not find anything strange, so try using the "show hal configuration" from the "machine" menu to watch the charge pump pin if it gets active when you enable LinuxCNC.
- liutas4x4
- Thank you received: 5
1 year 6 months ago #327358
by liutas4x4
Replied by liutas4x4 on topic Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Problem 1: gelöst
Wie hast du das Problem gelöst?
Ich habe den gleichen Fehler.
Eugenius.
Eugenius.
- ChironFZ16
- Thank you received: 12
1 year 3 months ago - 1 year 3 months ago #332104
by ChironFZ16
Replied by ChironFZ16 on topic Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Ich hatte das gleiche Problem und mit sudo dpkg -P raspi-firmware gelöst
Last edit: 1 year 3 months ago by ChironFZ16.
The following user(s) said Thank You: Danny1107
Moderators: Muecke
Time to create page: 0.406 seconds
